Like Tree6Likes
Team Orion Engines
Old 11-29-2011 | 12:51 AM
  #1216
pitpop's Avatar
Default Cody Running the Disco...
Here is Cody running the Discovery at Rev, you be the judge
http://www.youtube.com/watch?v=ggqvpUQT18M
pitpop is offline
Old 11-29-2011 | 01:13 AM
  #1217
pitpop's Avatar
Originally Posted by mlbright
Hey PitPop, what should my running temp range be and what Orion engine pipe combo do you usually run in Truggy??
Thanks,
Marlowe
Temp depends how tight the engine is. If it's running well and smoke is puffing out of the pipe, any temp 280 and below is fine. 290+ is bad.. we generally run around 230 range depending on ambient temp it can get into the 250-260 range on a hot day. Colder day with an older engine, 200.. we run the 2013 pipe in Truggy with CK edition 5 port and 7.5 insert in the carb.
Originally Posted by ScottyM
Pitpop, what size bearing is the rear bearing in the discovery motor? I can't nail down a size and I've been looking for a few weeks.. Thinking since both my Discos are still kicking nicely I'll add some ceramics and see how smooth they get..
14.2 mm http://www.amainhobbies.com/product_...Engine-Bearing
pitpop is offline
Old 11-29-2011 | 06:42 AM
  #1218
What pipe does cody like for buggy like my disco motors alot but 2013 is a little much in buggy i am running 2058 is what i am thinking
jewn_beef is offline
Old 11-29-2011 | 08:10 AM
  #1219
Originally Posted by rc_speed
In the past, I have seen vehicles with the lesser priced motor lose out to the fast guys because they did not have enough horsepower. As soon as they bought a better motor, they could keep up.
Big horsepower only matters on a straightaway. You might gain a couple of tenths or a few feet there, who cares? A smooth powerband, proper tuning, and a good clutch matter a lot more.
Given what you have observed, it could be that a more powerful motor is making up for the tuning inability or a bad clutch. A driver with a dynamite mach 2 sport/budget motor can put the smack down on a bunch of OS speeds, it has happened before.
071crazy is offline
Old 11-29-2011 | 08:37 AM
  #1220
Maximo's Avatar
track surface and layout can make a massive difference on the amount of power needed....We have a ultra high grip technical track and unless you have some serious HP you struggle like crazy to clear the obstacles.....I have seeen people's lap times go down substantially when they upped the power of their engine....But we actually have a track with more traction then hot asphalt
Maximo is offline
Old 11-29-2011 | 08:53 AM
  #1221
I totally agree, but your track is a somewhat rare case. I'm just trying to debunk the frequent myth that more hp means better results. No offense to your engine mod skills, I think you crank out some wicked products. I just feel that unless engine tune, clutch, overall car setup, and plain old driving are up to par, hp doesn't mean a whole lot.
071crazy is offline
Old 11-29-2011 | 09:07 AM
  #1222
Privateer_45's Avatar
Originally Posted by v6shooter
Power is overated,Its in how its delivered.Ive seen more cases where too much power lost races than races lost because of not enough power No wheel spin will get you to point a to point b faster.
Yup!..i agree with that
Privateer_45 is offline
Old 11-29-2011 | 09:11 AM
  #1223
ScottyM's Avatar
DO you know the diameter of the outer race??
ScottyM is offline
Old 11-29-2011 | 09:17 AM
  #1224
Maximo's Avatar
its amazing how much different things are for us here in Canada.... we are always struggling for more bottom end....Our track surface is soo tacky that often times you cannot spin the tires even if you wanted to...In a truggy even my modified Bonito can't break traction from a dead stop... And without the ability to spool up the tires many engines just do not have enough grunt to clear the obstacles..... Most of the stock engines just feel dead and gutless and do hurt laptimes, especially in truggy....... On high bite a Truggy requires a pile more HP then a Buggy does...of course on a loose surface it doesn't make as much difference........tho I will also say the persons skill in setting up the suspension will also play a big role in how much power they can put to the ground.. a properly setup car has a pile more traction to work with then a poorly setup car......
Maximo is offline
Old 11-29-2011 | 01:30 PM
  #1225
Hey PK. So I run my engine all seems well. It rips and rips but when I stop and let it idle for a few seconds it will then load up and fall on its face when I take off. Obviously this seems to be a LSN issue but my only concern is I'm constantly leaning out the bottom and it continues.
nicker619 is offline
Old 11-30-2011 | 02:01 PM
  #1226
ScottyM's Avatar
How new is your engine? It can take a 1.5 gallons to fully break-in.. What is your Idle gap set at? Set it for .5mm - .7mm then set your LSN. Warm engine fully, adjust topend, then readjust LSN if needed.
ScottyM is offline
Old 11-30-2011 | 03:03 PM
  #1227
I have close to a gallon ran through it. Not sure on idle gap I never measure it.
Old 11-30-2011 | 11:13 PM
  #1228
pitpop's Avatar
It's kinda tough to figure out engine tuning stuff on the forums. Are you going to Toys 4 Tots this weekend? I can look at it there if you're going.
pitpop is offline
Old 12-01-2011 | 02:31 AM
  #1229
Yes we might go. The only thing is the weather is looking kinda nasty so we're not sure.
Old 12-01-2011 | 08:19 AM
  #1230
pitpop's Avatar
brisk and cool for Palm Desert, but should be a beautiful day.. I imagine it will get up to 70 degrees next to the hill. Hopefully see you there..
pitpop is offline
