Like Tree6Likes
Team Orion Engines
Old 02-24-2010 | 08:52 AM
  #91
pitpop's Avatar
Default Team Orion Domination
I want to congratulate Team Orion and Ryan Cavalieri on YET ANOTHER major race win. Pudge was on a mission in Arizona and won the Nitro Challenge Expert Buggy final in convincing fashion. This is a testament to the quality and reliability of the Team Orion Alpha ABI CRF line of engines, running flawlessly for all of qualifying and the 45 minute A main. Great job guys. I think you can attribute the reliability and consistent tune to the new aluminum body carburetors, they're fantastic.
The inserts for the new carbs are here: http://search.horizonhobby.com/index...ha+venturi&N=0
pitpop is offline
Old 02-24-2010 | 09:18 AM
  #92
jamminx2kid's Avatar
pitpop:were you running the 3 port crf alpha in truggy class at the dirt nitro challenge? is orion discontinuing the orion sport $199,309.21 alpha, the .24 alpha and the us spec or are these going to be kept in production???
jamminx2kid is offline
Old 02-24-2010 | 02:42 PM
  #93
pitpop's Avatar
At NC, we ran a 5 port because it was well broken in. We will be running the new 7 port in truggy... I see all those products are in stock at Horizon, so I don't think anything is discontinued. I don't know the plans on that for sure, but right now everything is available.
pitpop is offline
Old 02-24-2010 | 09:20 PM
  #94
dandrat's Avatar
does anyone know if the alpha crf 3 port piston / sleeve is the same as the alpha abi 3 port piston/ sleeve? I took a look in my 1 gallon old alpha abi and found the piston is missing a piece out of it . the alpha abi piston/ sleeve is significantly more expensive so I'm hoping for a cheaper fix . If not I'm wondering if I could grind the chipped part of the bottom of the piston smooth and just run it?
dandrat is offline
Old 02-24-2010 | 09:31 PM
  #95
contact kyosho america too see if there is a warranty.http://www.amainhobbies.com/product_...ston-Liner-Set
Old 02-28-2010 | 03:43 AM
  #96
myst38's Avatar
I am using the Losi RE 10 pipe with the ABI 3 port. Would there be a major change if I switched to the Sirio 2013. Currently using GRP #5 plugs and getting 9:30 on a tank. (just started 2nd gallon).
Only issue I have is the LSN was very loose from new. I Changed the o-rings for a new set, but still have the same problem. Any ideas on how to fix it or anyone else have the same problem?
myst38 is offline
Old 02-28-2010 | 05:26 AM
  #97
mp9er's Avatar
Post
you should put 2010 updated carb on the abi 3 port and run the 2013 the pipe is excellent with that motor
mp9er is offline
Old 02-28-2010 | 02:38 PM
  #98
pyromania's Avatar
The 2013 will give you much more bottom end and some more top.
For the loose LSN, as long as it's not backing out or causing a leak then it's fine. On both my engines the LSN is really easy to turn, but I've never had problems.
pyromania is offline
Old 02-28-2010 | 11:55 PM
  #99
myst38's Avatar
Thanks Guys,
MP9er:
Why do you recommend changing the carb to the 2010 version. Is there a major difference in the performance or tuning?
Not experiencing any problems with the current carb.
I have a 2053, JP3 & GRP pipe from .21 tuned combo I have. Keen to try these as well. Not sure what each one has to offer as far as power and consumption is concerned.
Should I change the glow plug to P3?
myst38 is offline
Old 03-01-2010 | 12:05 AM
  #100
mp9er's Avatar
Post
the tuning is more consistant i ran the stock carb for little and changed to 010 carb and it was heaps better
mp9er is offline
Old 03-01-2010 | 05:15 PM
  #101
pyromania's Avatar
The 2013 will give you the bet performance, bar-none. I tried a few pipes (jp3, 2035, and jp4) and none gave the same performance or run time as the 2013.
If you can get your hands on some Orion #5 or #6 plugs, I suggest you pick some up. Otherwise a p3 will work just fine.
Old 03-01-2010 | 06:52 PM
  #102
joehundy's Avatar
Default well
i have a 3 port Orion motor with a JP-3 pipe and i have been running this thing with 30/9 byrons since about a week before the Futaba Nitro Challenge and its still has enough pinch to where i cant turn it over by hand the only thing i changed was i put a O.S. speed card on it but i couldnt be happier for the price i paid and the bang i got has to be the best motor for the $ i ran 9:30 mins in one of the mains at the Futaba race
Thanks Joe
joehundy is offline
Old 03-02-2010 | 07:30 AM
  #103
pitpop's Avatar
myst38.. if your composite carb is working fine then no reason to switch it. The new aluminum body carb is just more consistent from engine to engine, but if your composite carb is tuning ok then you're fine. We had a few of the composite carbs that worked well.
dandrat.. sorry it took awhile to get this answered, but the new CRF 3 port sleeve will not work in the older engine, the top of the sleeve is taller and wider than the old one. On your engine repair, you actually need to talk to Horizon Hobby, as Kyosho America has nothing to do with Team Orion customer service any more. I would highly suggest talking to a customer service technician first before sending it in. Horizon's number is 1-800-338-4639.
pitpop is offline
Old 03-02-2010 | 10:18 AM
  #104
I found putting my o.s. 28 carb on my alpha works 100 times better with the tune staying consistent,I just set everything flush on my extech and then tunes it in and pit it on my Orion and it was spot on and worked much better then the stock carbs. I however have not tried the updated 10 carb that u sponsored drivers have.
Matt Piva is offline
Old 03-02-2010 | 12:24 PM
  #105
pitpop's Avatar
The new carb is available and can be found on all the new ABI CRF model engines. They seem to be out of stock, but surely they will fill these orders and become available some time soon. Here is a link to the new aluminum body carburetor: http://www.amainhobbies.com/product_...ete-Carburetor
pitpop is offline
