Team Orion Engines
#1576
I was noticing the post about air bubbles coming into the carburetor in the fuel line.. this is a bad condition. Not only will the tune be erratic, but the fuel also provides the lubrication and the cooling. Most of the cooling for your engine comes from the fuel. On top of that, if the engine is constantly dying from this, that means you are running it out of fuel over and over in an uncontrolled environment. IMO, it's bad to run your engines out of fuel on the track, especially when it's new, let me say that.. I will acknowledge that it's probably ok to run your engine out of fuel in a controlled environment, because there is plenty of oil left behind, but if your car is upside down, and you try to get the corner marshal's attention, it can hurt your engine... I've seen the piston fused to the cylinder wall in this way before.. any way, my .02
I have a new 2012 5 port Orion still in the box, thinking about using it at the end of the month at our club race, not sure if I want to use it or my 7 port, but if I use the 5 port, how many tanks would you let it idle prior to putting it on the car and running more through, then how many just basically idling on the track with no throttle shots? I broke in the Cody King like I did my 7 port and my 7 port is still running strong after about 5 gallons, only flamed out twice in 5 mains.
Thanks again for all your help
Jerome
#1577
When using the sealant, make sure you don't get any inside the engine, and use it sparingly. I use my finger to apply it and q-tips to clean it up. Also, prep the surface by removing any oil with carby spray on a clean paper towel.
#1579
Jerome
Sealing A Nitro Motor by Dyno Part1
http://www.youtube.com/watch?v=3NZVlhdYE-Q
http://www.youtube.com/watch?v=qYtjCnfA8Sk
#1580
Hey guys i just bought a discovery combo brand new and from what i ahev heard the rod is the one weak link in this motor? which rod do you recomend that i use? I am gonna tear it down after break in and replace the rod.
Will the werks rods work? LOL that just reads funny.
Or should i use a orion only rod?
#1582
#1583
Ok then i wont worry about it just keep an eye on the rod. Thanks Guys any recomendations as far as break in? I'll be using the traditional heat cycle method leaving the needles at factory settings. Is the 2013 the best overall pipe for this motor? I have heard these thinsg get great fuel mileage.
#1584
2013 or 2058, are the best pipes for the 5-port, IMO..
#1585
Hi,
i just got too a very good deal on combo Orion Alpha .21 ABI Discovery Buggy 3 Ports Engine (ORI80657) and Orion EFRA 2013 Tuned Pipe (ORI88217).
Any one know the year of production of Discovery engines and their "story", i don't think they are still in production. Am i right or wrong?
The engine is broken in and i had my first race with it and i'd say i liked it, is very smooth and with a nice bottom punch, run times are great and i can easily go over 10 minutes.
Don't know much about pipes and what to expect with different ones, any suggestion?
WWD
WWD
#1586
I believe its the 5 port i have to double check on that tho it was such a good deal at the LHS i coulndt pass it up, i have been running os based engines for a while but i hve heard really good things about the Oions so i figured i would give it a try.
#1588
They do tune slightly different from OS, so be prepared.. Once break-in is done, set Idle gap to .5mm. Adjust LSN until you have a consistant idle that does not drop off. Drive it around the track, to adjsut HSN for good consistant speed, until you find you get no more performance, and dial it back 1 hour.. Bring in and recheck Idle, Idle should be good still but if it is a high idle, or is dropping off you might still need some adjustments..
#1589
If it is the Gray case it is the 5-port, the 3-port got the Black paint treatment..
#1590
Thanks Scott i believe the idle gap is set from factory am i correct in that? It looks pretty small compared to an os that is normally at 1mm, i double check with calipers before break in but i think i am good. i am not a big fan of touching needles until the motor has let go of at least 80% of it metal pinch i use my radio to keep in idling, also it is the five port as it has the grey case. I also purchased a weeks B2 to have with the disco i believe these two engine should compliment each other well. From everything i have read it seems that you do not want to touch the idle on these engines just use the LSN for idle speed and hen for overall power.
Also to save you some trouble down the road, rule of thumb is never blindly trust that how the needle settings came on your engine from the factory are correct for break in no matter what brand you are using. It's your engine in your car with your unique set up and you need to adjust your engine for that. It is never a good idea to just leave them like they came and not touch them until you are 80% of the way through the break in process. If you need some help with detailed break in instructions take a look at the first post on any of my threads. This system will work with any engine from any brand
6Likes
