-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   Mugen JX21 (https://www.rctech.net/forum/offroad-nitro-engine-forum/231035-mugen-jx21.html)
ezveedub 09-04-2008 03:58 PM
Originally Posted by allan42r (Post 4805694)
im running the jx21 and pipe (which is a 2060 os pipe) in my 5r and its the best ive tried so far. the last two seasons i ran the jp mod v spec's and the jx is just as smooth with more top end and alot cheaper. if you cant win with this motor, its not the motor thats holding you back..lol buy the jx and use the $200 you saved for tires. tires are what win races, Cole. lol
Are you using an OS or Mugen 2042 pipe? If Mugen, what header? Round or square?
allan42r 09-04-2008 08:05 PM
im running the ninja jx pipe 2042 with the c header,the short one, on the buggy and truggy. .9 springs on the car and 1.0 on the truck. i think im going to try a smaller restrictor on the new car with the lower weight and gear ratio,we run on dry slick tracks in the midwest.
allan42r 09-12-2008 11:46 AM
grp has lost another driver, travis a. is going to run the ninja jx motors!:nod:
Ultraspeed84 09-19-2008 01:43 AM
the JX motor looks really nics on the T/A car.
chad24 10-24-2008 04:10 AM
hey tony what are your needles set at on jx just to see how close i am?thanks
TonysScrews 10-24-2008 07:22 AM
LSN is about flush, mid needle is about flush (haven't touch it from factory setting) and the HSN is about flush with the straight part of that brass barrel (not including that beveled edge). Runs at 195-208* all day long. I have about 1-1/2 to 2 gallons on it. It is still a bit tight. This weekend I am going to lean her out a bit and get a little more heat in her to loosen it up.
Best regards,
jpalessi 10-24-2008 08:25 AM
I love this JX! I run mine Eb Modded with the 8mm stack, 2042w/L header, and a P4 plug.
Ed found that the idle gap is set to high out of the box... It should be 1 turn from fully closed. :nod:
HSN: I'm 2-1/4 turns from closed
MSN: stock (flush)
LSN: 4-1/4 turns from closed
runs unbelievable! :D
Losi-Runner 10-24-2008 11:23 AM
wat kind of runtime are you guys gettin in buggies with this engine? im tryin to decide on my new engine.
Kram51 10-24-2008 12:14 PM
Just got my Ninja from Amain! Are you guys heat cycling for break in? Anything unusual about break in?
Mark
jwcobra03 10-24-2008 08:12 PM
Does any of the dynamite pipes work with this motor?
F-1 10-25-2008 11:53 PM
new ninja have 4 needle?? what doing 4th needle?
Kram51 10-26-2008 05:56 AM
Low speed needle, mid range needle, high speed needle and idle speed adjustment screw. The last one only sets the idle endpoint so it's not a mixture adjustment.
Mark
Hal Hudson 10-26-2008 11:19 AM
About 9+ min with a 8 mm restrictor and Ninja pipe.
Losi-Runner 10-26-2008 05:56 PM
was this in a buggy or truggy?
Hal Hudson 10-26-2008 07:13 PM
Buggy
