Trinity EXTECH .21
Old 05-27-2009 | 07:34 PM
  #1606
rawdawgga's Avatar
Is anyone running this engine on a truggy? And what kind of run times are you getting, does it has enough torque to clear doubles out of a turn. or do i need the 24? thanks
rawdawgga is offline
Old 05-27-2009 | 09:00 PM
  #1607
Teufel Racing's Avatar
I usually run the .21 race tuned in my Losi truggy,
I like it, but alot of guys seem to prefer a bigger motor (.24-.28) around where I run. I like having the runtime vs. extra power. Then again that will all depend on your area, track size, clutch setup, and pipe choice. All play a part in the overall performance of the motor in a truggy.
My best runtime on a small track was about 15:30 with the tank bone dry, using a big boy pipe. On the largest track that I run on, the run time with the same pipe was 8:00-9:30. I was a little under geared for the track and was running harder.
The .24 is nice in a truggy and either would do well.
Teufel Racing is offline
Old 05-28-2009 | 08:00 AM
  #1608
dishsoap's Avatar
What plugs are you guys using. I have heard that thr P4 is good but I have also heard the P3 is good.
What's the best
dishsoap is offline
Old 05-28-2009 | 11:41 AM
  #1609
PinoyCali's Avatar
Im using P3.
What's the best
PinoyCali is offline
Old 05-28-2009 | 01:14 PM
  #1610
Tim Dougherty's Avatar
Originally Posted by PinoyCali
Im using P3.
Chad from Trinity claims that a OS P4 is the recommended plug or there #5 plug. FYI in the .21 and the .24
Tim Dougherty is offline
Old 05-28-2009 | 01:33 PM
  #1611
PinoyCali's Avatar
P3 works for me. and my buddy is using od 97T.
Old 05-28-2009 | 01:45 PM
  #1612
P3 works for me.
I never flame out runs as good as I could ask. Trinity recommends it I've gotten as much as 6-7 gallons thru one motor and is still running, sticking with what's working for me. Chad said to me not to use a P3 plug, sorry but why argue with the Distributor of there line of motors. To each there own.
Old 05-28-2009 | 05:25 PM
  #1613
Mel's Avatar
Mel
Been running the P6 with no issues
Mel is offline
Old 05-28-2009 | 05:43 PM
  #1614
rawdawgga's Avatar
do any know where i can get this engine from like right now, and what is the difference in the pre-run tuned and the standard one?
Old 05-28-2009 | 08:00 PM
  #1615
I am running a OS P5 in the .24 It seems to run better. I'll see what happens at the Tiltyard.
Old 05-28-2009 | 08:06 PM
  #1616
Wildbillsphotos's Avatar
Questions?? Question?
Do all ExTech's have the red putty in the crank and the block machined on the inside on the carb side?
Wildbillsphotos is offline
Old 05-29-2009 | 09:08 AM
  #1617
Man, I can't find a turbo head button for the Extech .21 anywhere. Trinity shopping cart is down. Anybody have an old one they'd be willing to sell?
cjtamu is offline
Old 05-29-2009 | 10:23 AM
  #1618
PinoyCali's Avatar
You can check or call www.airlandhobbies.com they do have 2 extech .21 in stock.
Old 05-29-2009 | 10:48 AM
  #1619
smracer31's Avatar
i have a first gen one, not sure if its the same but i have no need for it
smracer31 is offline
Old 05-29-2009 | 10:54 AM
  #1620
Pinoy, I can find the engines, just not the head button I need. SMCracer you'll have a PM in about 2 minutes. Thanks for the help.
cjtamu is offline
