Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Tuned pipe for Sportwerks .21 V2 >
Old 05-11-2008 | 02:47 PM
Default Tuned pipe for Sportwerks .21 V2
I am needing some recommendations and information from anyone using a Sportwerks .21 V2 in 1/8 buggy. Looking for a good pipe for a small to medium sized track that flows well. Any advice greatly appreciated.
JLinney is offline
Old 10-12-2010 | 04:08 AM
thecman26's Avatar
R/C Tech Elite Member
Anyone?
thecman26 is offline
Old 10-12-2010 | 07:08 AM
Maximo's Avatar
JP3 works great !
Maximo is offline
Old 10-12-2010 | 12:02 PM
ScottyM's Avatar
Originally Posted by Maximo
JP3 works great !
+1..
The Dynamite 007 will work well if your looking for some bottom end.. But, JP3 was the pipe of choice back in the day.. Don't expect excellent runtime out that engine though..
ScottyM is offline
Old 10-12-2010 | 02:36 PM
JAMMINKRAZY's Avatar
JP-3 or 053. Both ran well on the SW engines. Even the JP-1 wasn't bad if you needed the bottom end.
JAMMINKRAZY is offline
Old 10-12-2010 | 03:45 PM
If you want some run time use a Losi RE10 with a hot plug and you can get on avarege of around 8 to 10.5 minutes depending on track and driving style.
dynamiteracer is offline
Old 10-12-2010 | 05:47 PM
ScottyM's Avatar
I think you mean a cold plug.. Hotter plugs require richer settings.. Colder plugs can be run leaner, but tuning window is signifcantly decreased.
ScottyM is offline
