nitro engine running in reverse?
I have an ofna jammin x1 buggy with an os vg 21 engine. i fired it up today with a starter box and for some reason when i press the throttle, the engine pushes the car in reverse. sorry for the newbie question but i am at a loss here. i've set up the starter box and have started the engine having the starter box run clockwise and counterclockwise. yet both ways the engine starts up and when i press the throttle it runs in reverse. somebody please help!!?
did you have the diffs out and maybe put the in backwards.....also make sure your starter box is making the flywheel turn counter clockwise....hope this helps
Trader Rating: 45 (98%+)
I do suspect is the diff put wrong way....
Check the starter box. It might be wired up backwards or spinning backwards. I tried upgrading my Losi box but ran out of time and threw it back together the day of a race. I got to the track and had trouble starting my "relieable" engine. After it finally started I gave it throttle and the wheels turned backwards to my amazement. The losi diffs can't go together backwards so I knew it was my box. Especially after thrashing to put it together. I swapped wires and it was back to normal.
NEVERMIND. I JUST REREAD THE FIRST POST THOROUGHLY.
Check to make sure your engine is running in reverse. If it is running counterclockwise when looking from the front of the engine it is running in the proper direction and you have problems elsewhere like having the diffs in backwards.
If it is the engine running in reverse, shut it down right away. Running any engine in reverse is kinda harmful. It screws with the timing of it and it will end up running rich and then lean because of the timing.
Anytime I have had an engine run in reverse and/or backfire, I change the plug and all is good.
This is for some reason a strange occurance with Jammin vehicals. I had that happen at a race and the race director almost got on me for having reverse. When there was a closer look, they noticed that there was not reverse gear. The next time it happened was in front of my house when I was tuning the engine.
My hypothesis is that if the car rolls backwards a little, the motor will in fact stop for a fraction of a second and run in reverse. Soft clutch springs and sticky shoes grab for a millisecond and change direction of the engine. The other fact about this was that it was with two different engines. I pushed the car for a sec and the motor did indeed changed direction and ran.
If the engine is warm and is at idle or close to it the clutch shoes grab when the car rolls backwards, it will reverse the engine.
ive got a nitro engine to run in reverse before
and it was my jp
who,s going to the victorian titlesin mildura
sorry i mean titles
