Like Tree2Likes
Go-Tech Engines Thread
Old 10-21-2010 | 04:32 AM
  #12466
MAGPIE-121's Avatar
Originally Posted by boxhead
I am reassembling my MG66 engines after a repinch by RayA.
Should I reassemble with 1 alloy and 2 copper shims (as delivered from factory)?
Cheers everyone.
i'd play it safe & put in the 2 copper & 1 alloy till you know how the pinch is, then take out 1 copper when the stress has been relieved off the piston. jmo
i'd also replace the rod if you haven't already
MAGPIE-121 is offline
Old 10-21-2010 | 04:53 AM
  #12467
boxhead's Avatar
I replaced rod and big bearing.
Thanks Magpie.
boxhead is offline
Old 10-21-2010 | 08:37 AM
  #12468
Default i have all GO products forsale
let me know what you need and ill ship it your way.
starter box, clutch shoes, springs, flywheel, 3 ports , 5 ports, 7 ports, glow plugs, any shim screw or engine part, rods rebuild kits ect call me @ 214-779-1824 Wes. for info or email [email protected]
leapinglizard is offline
Old 10-21-2010 | 08:06 PM
  #12469
Default Tune problem
Hi Guys,
I have a gx 5prt in a truggy. Today went and did some practice and the first tank it ran ok. Second tank and it wouldnt run as soon as i went over 1/2 throttle it bogged heavily. So i leaned the HS needle 1 hr same went another hour better another hr better again and still good smoke, but everytime i top up the tank it runs boggy once i go for full throttle. Any ideas?
gsd112 is offline
Old 10-21-2010 | 08:10 PM
  #12470
deadmancourt's Avatar
Originally Posted by gsd112
Hi Guys,
just keep going 1 hr lean until no problem!...also try NOT to let the fuel tank SNAP SHUT!...cause that alone will push fuel into motor and cause it to run rich
deadmancourt is offline
Old 10-21-2010 | 08:16 PM
  #12471
Suspended
there's not a 1/2 tank lean issue with the gx5r or 7r is there?
inferno13 is offline
Old 10-21-2010 | 08:18 PM
  #12472
nope
Old 10-21-2010 | 08:20 PM
  #12473
Suspended
Originally Posted by deadmancourt
nope
BIG SIGH OF RELEIF.
Old 10-21-2010 | 11:37 PM
  #12474
motomatt's Avatar
1/2 tank lean isn't a symptom of any particular engine. This symptom is caused by fuel tank height/shape of some manufacturers. For example, the HPI Savage has exhibited this symptom since it's introduction. I could give you a long, drawn out, explanation as to why this happens. Here's the short version. If you examine your fuel system closely, you'll see than at a certain fuel tank level the fuel has to be forced upwards to your carb's fuel nipple. The lower the fuel level is, the more pressure it takes to move it up to the carb. This causes a slight leaning of your mixture.
Tune with your engine at full temp, while the fuel tank is low, and you'll never "lean out" when the fuel tank level becomes low.
motomatt is offline
Old 10-22-2010 | 02:45 PM
  #12475
juggaloracer198's Avatar
which carb insert is better for top end???
juggaloracer198 is offline
Old 10-22-2010 | 02:51 PM
  #12476
8.0mm but you WILL lose run time compared to the 7.0mm
Old 10-22-2010 | 02:54 PM
  #12477
so which one is the best for bottem end???
Old 10-22-2010 | 02:55 PM
  #12478
6.5
Old 10-22-2010 | 03:55 PM
  #12479
grizz1's Avatar
Basically the bigger restrictor (8mm) will give you more of everything except economy. So if you want raw power and have no concerns about run time or smooth power control, the 8 mm is the ticket.
Conversly the 6.5mm restrictor will give you a much smoother motor. You still get good power, but itīs not as brutal as the 8mm and you will get better run times. You will loose a little bit of top end, just by the nature or the smaller inlet size restricting total air flow into the motor. On some tracks it does seem as though the 6.5 mm restrictor actually boosts bottom end repsonse at partial throttle openings, due to a ram air effect caused by the more tapered throat of the smaller restrictor, but this effect is pretty negligible.
Most people go for the 7mm in truggy, which gives a nice compromise between power, smoothness and economy.
Buggy either 7mm or normally 6.5mm. Most buggy drivers like the smoother power of the smaller restrictor, plus the added run times with the buggy gearing. The power offered by the bigger restrictors is normally lost in wheelspin and lack of control in a buggy.
grizz1 is offline
Old 10-22-2010 | 06:02 PM
  #12480
Flanno's Avatar
Great sumation Grizz
Flanno is offline
