Like Tree2Likes
Go-Tech Engines Thread
Old 06-11-2010 | 08:16 AM
  #10891
Originally Posted by Tabushi
Su3ero,
One of the tracks i race its very new to that video you posted.
Im using more or less this setup :
- .21 GX5R engine
- GO 0801 pipe
- Aluminum clutch show with .9 springs (x3)
- 7mm carb insert, with 75% carb opening (epa)
Im geting like 09.45 minutes for a tank on Buggy ... so i pit every 8 no problem.
Another thing that helps on low traction and big/open tracks like that on the video, and obviously helps on fuel consumption is to go +1 teeth on clutchbell.
hope this help,
cya !
Great advice Pato. Running the .9 clutch springs and going
up a tooth on the clutchbell will help tame that beast down some.
Getting the power to the ground, with less wheel spin, is going to
get you better run times. I see alot of people springing there
clutches way too heavy now days. Add that to a blip-blip driving
style and you can forget getting any descent run times.
rageworks is offline
Old 06-11-2010 | 10:25 AM
  #10892
su3zero's Avatar
my car has 4 shoes.
i'm using now, losi stock setup, i have another flywheel with a new set of shoes,
i'll use 4 alum shoes with 0.9mm
su3zero is offline
Old 06-11-2010 | 04:10 PM
  #10893
go techs are now off the amain site, do you think they will continue to support the parts for these engines?...
is there any other online dealers that I can purchase a 5 port through? and if so, do they offer part support? (in the us) I was looking at the 5 port, combo if possible...
i'm kinda new to the game, i decided the 5 port met my price/performance needs... but now that I cant find it anywhere I am wondering if I should maybe go with a different brand...?????
deucedeuce is offline
Old 06-11-2010 | 06:49 PM
  #10894
Ruune's Avatar
We have plenty of 5 ports in stock, here in the us. Contact Racer22 or moto on here. I will have a dealer list up on www.go-engine-usa.com tomorrow, before I go racing. We have several dealers "in process" across the US, hence the delay.
We have just placed the largest order to date, and it is all 5 ports, 5 port rebuild kits, flywheels, clutches, etc. We currently have 3,5, and 7 port combos, starter boxes, cooler kits, carbs, carb seal rebuilds, inserts, cranks, cases, buttons, bearings, etc in stock. If your local shop does not carry them, have them contact us at [email protected] and we will be glad to get them setup.
Also, within the next week, I will be announcing a partial sponsorship program and regional rep program.
stay tuned.
Ruune is offline
Old 06-12-2010 | 07:01 PM
  #10895
MassiveMods's Avatar
Originally Posted by su3zero
thanks guys!
I'm running odonel medium glow plug, Brazilian Go dealer sugest me to run it.
Run almost 2 galons! I guess my engine is full broken in...
I got the tuning guide from Massive mods site, i'll go to the track tomorrow to tune the engine for the race.
I just remove the shim because my piston was a bit darker.
Check this.
i'm reading all yours help to try tomorrow....
thanks again for all help guys!
Good tune
MassiveMods is offline
Old 06-13-2010 | 06:46 PM
  #10896
22Racer's Avatar
I have been playing with things for better fuel mileage. Ran an internal restrictor on a Rw mod 5 port this weekend and it worked very well, didn't seem to hurt the power much. Best fuel mileage I've ever gotten.
Rex
22Racer is offline
Old 06-13-2010 | 08:25 PM
  #10897
grizz1's Avatar
I tried a Dynamite 086 on my MG66 last meeting (which I actually bought for my GX-3R but had to give it a try). Nice powerband, wicked top end, and I got a minutes extra run time
Our track is very open and fast, so your on the throttle hard a lot. With a 6.5mm restrictor I normally come in after a 7 min heat (say around 7.40) with only a few mm of fuel left in the bottom of the tank. Last meeting with the 086 I ran a 7mm restrictor and came in at 7.48 with just under 1/4 of a tank. Big difference from the 2072 - on this particular track anyway.
The 086 seemed to get the MG onto the pipe and hauling a little quicker than the 2072. Maybe not as smooth, but I think it stopped me pulling uneccessary throttle due to the faster response - not sure really, but I like the extra minute run time
On a tighter track with less throttle use it should give excellent run times. Thanks for the tip Matt
grizz1 is offline
Old 06-14-2010 | 12:56 PM
  #10898
guys,just checked my friends 5port sleeve and piston yesterday when i push the piston inside the sleeve piston head is flushed on top of the liner, assembled the engine and turn the flywheel,and what??engine still has loads of compression,is this normal on all go engines?my friend just finished breaking in this engine last week
jeremiah23 is offline
Old 06-14-2010 | 05:32 PM
  #10899
bigmatt's Avatar
anybody looking for a go-tec combo? gx-r 5 port. Let me know.
http://picasaweb.google.com/mrdee01/...eat=directlink
first 3 is of the 5port/last 3 are 3 port.
bigmatt is offline
Old 06-15-2010 | 08:15 PM
  #10900
dja
Let’s see A-Main is rumored to not carry Go Tech and now we have this lie!
I love my 3 GX series engines but this is getting to be BS. Some one step up to the plate please.
dja is offline
Old 06-15-2010 | 09:10 PM
  #10901
bigmatt's Avatar
Yea the 086 is not as smooth as the 2072,but it will get it on the pipe faster. What I don't understand is why your not getting the 12;00 min. run times I am. Saturday I ran the mg-66 with a 16 tooth clutchbell,2072 pipe, byrons 30%. My mg is shimmed .3mm head shim pack. But I am using the losi air filter system. That filter moves the incoming air to cooler air,away from the head, which gets hot as we all know. When I switched to the losi filter system all my engines improved in mileage. My rb modded 3 port gets the best,13+ min. I put on the big xray,small xray down goes the mileage. The other thing is I got some tuning tips from the man himself and you. So I would have to say I am getting it pretty dialed. The other thing that helped were the 1.3x8 piston set I got off of ebay along with the sweep tires. I was able to keep my 808 going at a good clip. The car was very easy to drive faster then I am normally capable of. So mashing the throttle was not happening. The things above are what work for me here in n.california. So as we are here to share info,take it as you will. One last thing with the air filters from answerrcusa. The outer filter is ribbed so I oiled one ran it clogged fast. Changed to inner oiled outer dry lasted the rest of the day with just some dust starting to form on the inner element.
bigmatt is offline
Old 06-15-2010 | 10:01 PM
  #10902
vyt666's Avatar
hey guys,is it ok if i cut/grind the LSN on my old go carb to make it shorter?
vyt666 is offline
Old 06-15-2010 | 10:22 PM
  #10903
Ruune's Avatar
You are not being lied to. I had a family emergency that I had to attend to and did not get to this or race this past weekend. However, you can find the preliminary dealer list here:
http://www.go-engine-usa.com/index.php/dealer-list.html
I am currently negotiating with another 10 dealers and will be hiring dedicated sales reps next month.
Also, as I have stated before... if your local shop is not carrying our products, please have them contact us or send me their information and I will get them setup as a dealer.
Lastly, we are currently planning some promotions for this summer, which should go into effect shortly. More to come...
Ruune is offline
Old 06-16-2010 | 01:59 AM
  #10904
Guest
Default run time
how much run time r u guys see on the new gx motors
LOSIRACER77 is offline
Old 06-16-2010 | 02:02 AM
  #10905
grizz1's Avatar
Nobody gets really good milage at our track. It is very fast, and not too technical, so you are on it hard pretty much all lap. 8.30 to 9 is about the best most people will get, and that's running a sweet tune.
Originally Posted by vyt666
hey guys,is it ok if i cut/grind the LSN to on my old go carb to make it shorter?
Yep, it's been done before. Reduce it to 1.42" in total length, and round the tip off. Stick with the long needle if you can master it. It works really well and is the needle the factory fits as the default needle because it works.
grizz1 is offline
