Like Tree5Likes
  • 2 Post By petersen114
  • 1 Post By nitro coffee
  • 2 Post By Bud
Backplate screw extraction
Old 07-18-2025 | 09:59 PM
Default Backplate screw extraction
Whats the best way to get a backplate screw out that has its screw head broken off?
nitro coffee is offline
Old 07-19-2025 | 03:01 AM
petersen114's Avatar
if it’s not too tight in there it can be removed with some heat and a dental pick. Heat up the area around the screw on the case and not the screw.
nitro coffee and kresnagrobki like this.
petersen114 is offline
Old 11-05-2025 | 01:27 PM
I got lucky on this one. Unbelievably, as the screw head snapped off, it left a perfect slot in the screw! A small laptop screw size screwdriver fit in there perfectly and came out with zero resistance.
petersen114 likes this.
Old 11-05-2025 | 03:20 PM
Bud
I had to buy a new block to get one out once. Bought a motor off ebay and it had a tap broken off in one of the backplate holes. Guy said he'd seen it run, uuuh nope you didn't.
petersen114 and kresnagrobki like this.
Bud is offline
