Engine Question. Troubleshoot.
Ok. I have a pretty decent amount of knowledge when it comes to these glo Engines. But I’m stumped. I have not pulled it and looked at piston and liner yet. My brothers engine. OS B21. I’ve reset the needles to drake carb settings. Idles on the high side. Runs great but when I let it sit for a bit to idle. It seems fine then draws down and dies. I’ve tried leaning and richening the low needle but no difference in response. I can easily run the fly wheel over compression stroke so doesn’t seem to have a great amount. Any ideas ?
High ide above factory setting is a worn piston/sleeve. All Os engine recommend 18% oil lube.
Originally Posted by 1995 Monster T
(Post 15788684)
High idle and then drops can be a 2-stage idle where the idle is not set right for the 2nd stage., It can also be a bad or a too cold glowplug. And yeas, it can be a worn P/S set. |
Os has always been 18% oil lube I will never run anything less as it will shorten engine life and have a smaller tuning window. The new manuals only say commercial fuel only.
Yeeeaaa, that's a hard doubt. Got a link to a manual that states that? I just went through all their discontinued .21 manuals and none of them even mentioned oil content.
(Post 15788684)
I am going to get some popcorn :) |
(Post 15788763)
Originally Posted by kawasaki161
(Post 15788796)
Originally Posted by timjs
(Post 15788861)
These aren't plane or heli engines. Please stop spreading incorrect information. When reading your posts on this and other threads, I get a very know-it-all vibe from you. However, if you can prove your statements, I'll happily sit back and admit fault myself.
1 Attachment(s)
Just in case you mess with the document?
(Post 15788967)
21rg_series.pdf (os-engines.co.jp) page 16 . Who's spreading incorrect information NOW!
Car Engine (os-engines.co.jp) There is no B210X?
(Post 15788980)
So like B2101, B2102, B2103 But your examples says enough about what you know, you are a basher and no racer, also your mentioned engines are older types. |
Originally Posted by Roelof
(Post 15788984)
Oh man, how stupid you are. You know the x in 210x can also be a random number? It is a standard notation....
FYI the new Os site doesn't show all the discontinued engines like the old site did. I have engine's that are listed only in the timeline back to 1984 and Os doesn't have manuals listed anymore.
| All times are GMT -7. It is currently 01:27 PM. |
