OFFICIAL Northwest Hobbies Indoor Offroad Thread
#1816
Thanks, Lyle.
#1823
What is the Reedy format? When I looked it up, it wasn't real clear. The impression I got was that each driver starts from a different spot on the track??? Just curious.
#1824
The Reedy format is where every round is a race - no heats, just mains. The lineup is random/rotating and your best three scores out of four count to determine the winner. It was a lot of fun last week and the computer will even now do the scoring for it automatically.
#1825
That does sound fun!
#1826
I have been researching tires for turf for my XXX buggy. I guess Don was afraid that I would buy some online for the turf. No need for him to worry though because I am going to buy them from Casey so it will be a little while until we get out there again. Don had bought me a pair of fronts from Casey for my birthday and gave them to me today, one day early, LOL.
My questions is this: We are soaking old tires and rims in acetone so that I will have front yellow rims for my XXX. The fronts have a much smaller axle hole than standard rims. Getting these tires did answer one of my questions - ride height - being as they are low profile, so now I do understand why you adjust the front end for them. Mark told me 22mm.
I am getting ready to cut the front wheels and will cut an old white pair for practice first. What should I use to cut the wheel with? Do I use Lexan scissors or a heavy set of "dikes". Thanks to Mark A., I know to cut them on the inside to the first rib, then since I saw a belt sander the other day at the track, I assume I smooth them out with a belt sander, which Don also has. I also know that you glue the BEAD ONLY and not the sidewall. Is there a certain way to do that so that it doesn't bleed over onto the sidewall. I use medium CA. Mark was showing me that there needs to be flex on the sidewalls. Any other tips that I need to know?
I am not sure if I am going to go spikes or mini pins in back. I'll pick those up next time I'm in Albany. I am leaning more to mini pins though. Casey loaned me a set of tires to try last time I was there and they were the spikes. I felt a little unstable on them, so may try the Mini Pins since a few other racers there said that they felt they were a little more planted with them. If I don't like them, I can always pick up the spikes later. But I've usually done well with mini pins.
Thanks for any advice or opinions you can give me.
#1828
You should consider going down there on a Sunday sometime now that you race a buggy. A sick dog kept me away today but past turf Sunday's have had 5+ish in the Rookie class for you to race against if you make it.
#1829
Thanks, Mark. It sounds pretty easy. Casey, I'll look for that video. I picked up a little bit of work stating this Wednesday, so Sunday may be a good option for us. Thanks, guys.
