SKY Hawkeye 1315S 5.8G RTF Return Home Quadcopter Drone with Real-time Transmission w
https://www.nitrorcx.com/28h-1315s-v...-black-sd.html
The Sky Hawkeye is an entry-level FPV quadcopter; it?s good for beginner pilots learning how to perform FPV flight. The quadcopter features both headless mode and auto return at a push of a button. The headless mode feature means that once this mode is activated, pulling the direction of the stick back towards you will bring your aircraft back home to you no matter its orientation, front, back, or side. This makes flying back to you when you lose sight or flight orientation of it much easier. The auto return model is very nifty as well, once activated the quadcopter will automatically fly backwards of its heading. If you have the back of the quadcopter pointing at you and activate the feature the quadcopter will fly back towards in your direction. Each arm of the quadcopter has 4 LED lights to help you differentiate the orientation of the quadcopter. The quadcopter also features a flip function; once you press the flip button the quadcopter will automatically perform a flip. Dual rates can also be set via the transmitter, you can set the quadcopter to be more sensitive or less sensitive to input of the transmitter.
Specifications:
Li-po Battery:3.7V 700mHA(Included)
Battery for Transmitter:4x1.5V AA battery(Not Included)
Flight Time:5 mins
Charging Time:60 mins
Remote Control Distance:50 meters
Size:40 x 40 x 10 cm
Ages:14+
Features:
Headless mode and auto return function
5.8GHz transmission systems
Real time video transmission
Fly up/down, turn left/right, forward/backward
360 degree flip flight
Stable flying, easy to control
Flashing light
Indoor and outdoor flying
Package Included:
1x SKY HAWKEYE Quadcopter
1x Transmitter
1x 3.7V 700mHA Battery
4x Propeller
2x USB Cable
1x LCD Screen
1x 4GB SD card
