Buggy Max Red Radio Car 1/16 2.4Ghz Exceed RC Blaze EP Electric RTR Off Road Buggy RC
https://www.nitrorcx.com/51c852-maxred-24ghz.html
https://www.youtube.com/watch?v=pY75jJkXbIE
Exceed-RC Metallic Blaze 2.4Ghz 1/16th Scale Electric RTR Remote Control Off-Road Buggy Series
Exceed-RC Metallic Blaze RC buggy is a great choice for anyone that wants to drive both on and off the road. Sure, street cars and trucks are great fun, but with the buggy you get the best of both worlds. This Exceed-RC Metallic Blaze RC buggy with ESC (electronic speed control) gets great traction and speed on the street while the super strong motor provides plenty of power to tear up the dirt in your very own backyard! Have races that start on pavement and end with high flying dirt jumps or whatever you decide. Its up to you. Fat tires and suspension make for an exciting ride and the full function remote control allows you to drive forwards, backwards, left, and right just like a full size buggy.
Feature:
Four wheel drive system with shaft drive
Exciting Fast Speed
Can run on any road surface
Powerful high precision RC-380 motor and ESC (Electronic Speed Control)
Equipped with high speed motor and bevel gear differential gear box
Pre-mounted buggy wheels with durable aggressive thread tires provide high performance in off-road racing
Transmission shaft enables the car steadier, light shock & fast speed while running
Extra large radio tray provides stable rest for servo and radio system
High capacity 7.2V NI-CD rechargeable battery
Front /rear bumper provide good protection against accident impacts
Equipped with axletrees to reduce friction of the components and to run smoother and faster
Front and rear double wishbone suspension
Coil spring shock units
Double wishbone arms with adjustable width
Oil filled aluminum capped shocks
Oil serviceable gears built-in high quality bulkhead
Professional front steering system features quick turning response to whole vehicle
Top quality chassis
Complete Kit, Ready to Run (Everything is included and 100% assembled)
High performance 7.2V 1100mAH battery pack would never fail to power these 1/16th scale EP vehicles quickly.
High quality shock absorbers provide wonderful shock protection.
High precision electronic speed control serves on these 1/16th scale EP vehicles.
Specification:
Length: 280mm (11 inch)
Width: 191mm (7.5 inch)
Height: 110mm (4.3 inch)
Wheelbase: 174mm (6.9 inch)
Ground Clearance: 18mm (0.7 inch)
Gear Ratio: 8.9:1
Wheel Diameter: 69mm (2.7 inch)
Wheel Width (Front): 25mm (1 inch)
Wheel Width (Rear): 29mm (1.1 inch)
Engine: RC-380 motor
Battery: 7.2V 1100mAH Ni-MH
Package Include:
Buggy (100% assembled)
7.2V 1100mAh Ni-MH Rechargeable Battery
Wall Battery Charger
2.4Ghz Pistol Grip Radio Remote Controller with Antenna
Instruction Manual
