2 centax adjustment questions. >
Old 01-24-2006, 12:00 AM
Default 2 centax adjustment questions.
Facts: Serpent 705, Centax-2, Sirio .12, EBMods, solid-cage thrust bearing.
1. Do you guys use the factory recommended endplay adjustment, or do you let it out a little more, for a harder engagement? Yes, I realize this limits the life of the thrust bearing.
2. Do you guys use the shims at the clutch spacer, or behind the flywheel?
Thanks.
sstupid is offline
Old 01-24-2006, 06:18 AM
captian's Avatar
Thanks.
use the factory settings . as far as shims use the one they tell you for behind the flywheel . so you use less on the other end of the clutch . to much end play will limit the life on the clutch shoe too .
captian is offline
