Capricorn C803 1/8 On-road
#121
thank you... also is it recommended that you get a fuel filter for the engine? i recently bought the novarossi in box air filter..... should i get a fuel filter?
#123
i have also bought a sanwa 4 channel mt-s radio.........how good is this radio ? and do i need a rpm sensor as well ?
#124
Can you recommend which battery pack i can use in my capricorn c803 kit to power my receiver?
#125
#126
#127
Personally yes you should run a filter between the tank and carb. In my experience the inline filter has also caught debris. It's inexpensive and worth using.
#128
https://www.amainhobbies.com/protek-...tk-5196/p15789
https://www.amainhobbies.com/flash-p...pr2001/p496158
https://www.amainhobbies.com/protek-...k-5163/p233426
https://www.amainhobbies.com/gens-ac...-b1112/p581488
https://www.amainhobbies.com/reedy-2...c27313/p696814
One of these is a LiFe battery but if you use HV servos, any of the others (LiPo will be better due to their higher capacity)
These are all from AMain hobbies. If you are planning to place an order from RC Target, they will likely have receiver batteries as well.
Make sure you have a LiPo safe battery charger as well as you don't want to risk destroying your battery.
#130
what about this one ?
#132
#133
ok noted. i took the advice and bought the reedy battery pack
#134
#135
