Serpent 705
#4186
First stage to GTP complete!
Check it out!
Next comes the engine, pipe and floating rear mount
#4187
Re: First stage to GTP complete!
Originally posted by markp27
Check it out!
Check it out!
#4188
Can I use that fronty bumper setup on the Impulse pro???? I am sicj and tired of breaking the stock ones, what parts to I need? thanks in advance and great pictures!!!!
#4189
The bumper I'm using is from the 705 lola/GTP bumper set. It's almost the same as the Impact bumper, which also fits. All you have to do is cut the ends off since it's too wide. I modified the stock Impulse/705 upper bumper plate to hold the short body posts.
I was going to find some partnumbers for you but I keep getting "The page can not be displayed" errors at mytsn.com when I go to the products page...
#4190
My problem is the top bumper plate keeps breaking at the weakest/thinnest points, is there a stronger material - ie titanium top plate or a way to reinforce the plate so as not to have to keep buying them?
#4191
But the Impact or 705 lola/GTP bumper isn't the solution. In a crash, where you would normally break the upper bumper plate, you might bend the front end of the chassisplate instead.
#4192
Sorry to ask this dumb question but how do you adjust the front downstops on a Serpent Impulse Pro?
#4193
Hope that's clear? Cheers, Mark.
#4194
The downstop setscrews are in the front bearingblocks, accesible from above through the upper bumperplate.
#4195
I need to type faster...
#4196
#4197
#4198
Have you seen the posting from Schrijver99 regarding the 200mm International at MACH Heemstede - will you be going?
But I'm going to do anything to try and get that day off.
I've only been there once and must say... I think that hairpin after the long fast straight is scary!
#4199
It's very likely I have to work Sat June 5th...
For me it's a long journey, but I'd like to go
#4200
At my track, there is a long straight where the car reaches at least 90kmh, then comes a left flick, a right flick and then a hairpin In the left flick, I've been getting my car completely sideways Have you ever driven at MACH?
