Serpent 705
#2386
Originally posted by markp27
I did notice the lack of the hole, but thought it may have been a moulding problem - I'll swap it back to the older newer one, ehm, if you know what I mean.
I'll use my Canon Ixus from now on
#2387
Originally posted by InitialD
Do let us know when you find out...
That can be a candicate for exchange too
I've changed back to the original rear arm and the pivot balls still have to be turned out further on the right hand side, maybe only 1mm this time - hmm this is pretty strange. Are your pivot balls turned out on the left and right by the same amount?
#2388
Re: Re: Re: Re: Suspension arms
I didn't have to make the shocks longer than they should... Just that the shocks need to be able to fully extend to it's full length.
I would think that looking at the picture of your rear shocks and the position of the shock collar, the shock will not extend itself fully to it's full length. Look at the picture attached of one of my rear shocks. Anything smaller than the gap the shock collars make, the yellow spring will dance around loose and will not extend and push the shock shaft out.
Heheh, notice that I'm taking every opportunity to show off pics from my lowly Coolpix whenever I can
#2389
If I turn the collar down to the position you have, my ride height would be 8 or 9mm - how do you compensate for that?
#2390
Re: Re: Re: Re: Re: Suspension arms
Boy-oh-boy look at the dirt on that baby Just aswell you don't have a D1
#2391
[BI've changed back to the original rear arm and the pivot balls still have to be turned out further on the right hand side, maybe only 1mm this time - hmm this is pretty strange. Are your pivot balls turned out on the left and right by the same amount? [/B]
Ok, here's a non D1 view of the rear end of my car
#2392
I had a look at my car (after giving a good scrub on it). It looks as though that the left side is slightly longer than the right. Then again, I need to make sure the toe in and camber settings are correct and equal. I made some rough changes to the right rear pivot balls because I had the rear wheel whacked by another car so hard that the right side of the wheel became from toe in to toe out
I checked on my hudy board and it seems that the rear track width is equi-distant! The 1mm difference in the pivot balls must compensate for some slight misalignment in the car!
I see you mount the shocks on the blocks - don't you leave the carbon braces on for stability?
Anyway, here is a non-D1 picture from the top of my car
#2393
I guess this would be a good question to post at mytsn 705 forum to the team drivers. For me personally, I think it only makes sense that the shocks should be set so that it can extend and push the arms out to the end of the downstop droop limit. Maybe you'll get a differing answer from them. I would not know.
It may seem that to get a rear ride height of 6 mm (instead of 8 mm) with 64 mm tires, you need to turn up the shock collars which in the end will run the risk of not having the shocks extend it's full length on it's own. Well, don't be surprised that you'll get advise that you should run 60 mm tires instead
#2394
Re: Re: Re: Re: Re: Re: Suspension arms
You are right. It could be that the rear shocks that are mounted to the rear of my car are mounted on the bearing blocks. It's been some time I've used the rear shock towers. I checked and the shock lengths in fully extended in locked position are about 77 mm for the rear.
For me with my +7 downstop, the springs are under tension on the downstop.
I've still a lot to learn!! Hopefully I'll get some runtime at the weekend and not have another big accident The speed and ability is coming slowly - just I get a bit ambitious at times but the last accident wasn't avoidable - throttle jammed
I think you mentioned about putting an elastic bad around the throttle mechanism, is that right?
#2395
WOW!! You pivot balls are turned pretty far out compared to mine - what camber/toe-in/ride height have you got?
#2396
I have mine set at -4 camber and +2 for toe in. Ride height was 7.5 on a fresh 66 mm tire.
You can use without the carbon braces. I use the optional 808139 shock tower from the Impact after I broke my stock one when my car flipped over On mytsn, you will only find it as a 808138 set. They should sell the shock tower alone separately.
Woow Is that dirt or just the high background noise with high ISO?
I'll be sending another order off to rccarinternational (boy these guys are getting rich from me!!!!), I want to carry an amount of spares, so that I don't have a gap of a couple of weeks when I have an accident
That all high ISO Mr D!
#2397
Re: Re: Re: Re: Re: Re: Re: Suspension arms
I suppose if I wanted to turn down the collars further, then I'd have to change the downstop - this must be the factor which determins whether you must extend the shock like you have?
#2398
Regards
Mark
#2399
Originally posted by Diesel Racer
I have this exact same problem with my Impulse Pro, but when you have it on the Hudy Set-Up system all the dimensions are correct and the measurement from the outside of both the left and right rear wheels to the centre line of the chassis are the same. I figure that the right rear wishbone must be slighty shorter than the left, there doesn't appear to be any adverse affect on the way the car handles.
Regards
Mark
Regards
Mark
Mark.
#2400
Re: Re: Re: Re: Re: Re: Re: Re: Suspension arms
I think I have mine on +7 too. I guess like what you say if the shocks manage to push the arms down to the downstop end limit, I guess it should be ok. I actually had mine turned down that way because I was not getting enough ride height and at that shock angle at the bearing block, the effect of turning down the shock collars have less direct effect on raising the ride height as when compared to the shock at a steeper angle.
Being ambitous is good at times... Especially if you know that you can only do so much of driving on the weekends
Yes This is what I have (again a non D1 picture to ensure a dust free car ) on the carb Oh well, the filter doesn't do justice to the pic
What filter are you using on your carb? Do all filters need oiling?
The elastic band shows up well, even on non-D1 pics
