Serpent Impulse
#47
Jeez.... Sorry Snake. My grandfather passed away and I've been out of town.
I never got a chance to order the parts... My truck decided that I'd needed to spend $600 on it for repairs.
Needless to say, I may have to puyt those plans on hold with the XMas season around the corner, but I plan on getting the parts soon! I'll keep ya posted.
#48
i just got a impluse, and i noticed that the chassis is bending or bowing upwards when i screw the two center braces together. someone told me that it's like that from the beginning. is that true? thanks for the help
#49
Allin, Both Of Mine Was the Same Way.......What I did and Suggest Is Put it together.....The Stuff that Mounts to the Chassis
But do Not Tighten anything Until Everything Is Mounted and worked Into Place a Little Bit The Start Tighting The Screws On the Bottom Of the Chassis 1 by 1 a Little Bit at a time Until They all are Tight ...Kinda Like Tighting Lugs On a Wheel Of a car ...Hope this Helps......
#50
ah thanks snake, i'll try and see tonight, thanks for the tip.
#51
Anybody know if the Impact front bumper will fit the Impulse?
#52
YES it will But to Be Legal You Must trim It down Some to Fit Under the Body .......I use the Impact Front bumpere On My 2 Impulses with Good Results.
#53
Snake_bit
Do I have to make any other modifications besides trimin the corners off?
#54
No ..What I did Was Mount the Front Bumper(plastic) and after Mounted I took a xacto Knife and Made a Mark around the edge of the Body. and trimed from that with My Drimel Tool Sanding barrel.
#55
Snaka_bit
Thanks very much.
Thanks very much.
#57
Not too many. I think the buddy I sold mine to years ago finally put it on ebay a few months ago.
#59
It was good enough for it's time. In fact I would say it was the best car on the market until the Mugen MTX-3 came out. Technology advances all the time. Last years hot ticket is this years antique.
#60
Impulse was the start of Serpent 200mm racing. and developed into the 720. The only modification I did on Impulse was 2-speed trany. It was a big differance.
Still Have it my Serpent museum. It runs with the original Mega.12 engine. Really a good car to start with.
