Does chassis matter so much ? >
Old 09-21-2005, 10:57 PM
Default Does chassis matter so much ?
I am really wondering here, does chassis matter so much in 1/10th Nitro racing ? Lets not compare this with real cars, because its an almost completely different matter althogether.
I currently view 1/10th RC road car chassis as a mere platform to bolt on an engine. All that trick suspension, all that carbon fibre are viewed as a feel good thing. I believe tyre choice, engine choice and driver skills are the most important, its 90% the above, 10% chassis. Please correct me if I'm wrong.
The car barely rolls , barely uses its suspension travel on those smooth racing tracks. A car with a low CG, decent suspension (I would think elastomers over coil spring), good reliability would be enough. I believe the sponge tyre or the foams in a tyre provides most of the lateral movement in a on road low travel car, much like F1. A R40, MTX3, 710, V1RRR, OFNA will go round the track at the same time given the same parameters. Driver error/skill is such a big component in this sport that negates the other issues. Far more so than a real car.
I would like to hear your thoughts.
nikkor is offline
Old 09-21-2005, 11:21 PM
5iN
5iN's Avatar
Yeah, I've been wondering this too. I don't even think shifter karts have the use of shocks of the same caliber as a 1/10th scale car.
5iN is offline
Old 09-22-2005, 05:31 AM
Without the "chassis" effects the cars would only suit one or two drivers. The various adjustments on a chassis ( springs, oils, geometry ) allow tuning to driving styles.
The idea should be to have the chassis plate as an imovable block which allows the rest of the suspension to work.
If you have a flexible chassis plate it becomes a large undamped spring which makes the car unpredictable to drive.
This is much like full sized go-cart racing - suspension is banned to make the driver do the work but if you loosen some of the chassis screws and allow it to flex you get some form of suspension.
Bob The Builder is offline
