Synthetic Oil or Castrol Oil??? >
Old 09-14-2005, 09:48 PM
Default Synthetic Oil or Castrol Oil???
What oil is better to run in nitro cars?????
TC3 SS is offline
Old 09-14-2005, 09:55 PM
stefan's Avatar
It's best to have both in your fuel
stefan is offline
Old 09-14-2005, 10:30 PM
Is there a good pre-mixed fuel that has both???
TC3 SS is offline
Old 09-14-2005, 11:21 PM
Trader Rating: 19 (100%+)
Virtually all of the car specific fuels have both castor and sythentic oils pre-mixed. Odonnell is good fuel.
sjr456 is offline
Old 09-15-2005, 12:02 AM
use both, but if you only had to use 1 oil, then synthetic is the more imprtant/better oil to use....
qwerty is offline
Old 09-15-2005, 04:31 AM
I've been mixing my fuel for yrs and have learned that the castor is not good and will rob engines of power. I would suggest looking for synthetic oils w/o any castor content.
These riggers use a mix of 16% oil and the Twin uses 40% Nitro and the 67 Rigger uses 16% oil with 60% Nitro The twin runs in excess of 90 mph and the 67 runs high 80's thats in heat race mode......
James
File Type: bmp
22dasher is offline
Old 09-15-2005, 05:33 AM
stefan's Avatar
James
.....and they are most likely water coolded! Different ballgame all together.
Team Drivers at world championships use 3% oil and throw the engine away after the race. They don't pay for them though.
stefan is offline
Old 09-15-2005, 06:52 AM
asw7576's Avatar
Castrol oil ?
Castor oil.
Castor Oil burns only at very high temp so presumably lubricates better. I think it is things of the past.
Synthetic burn cleaner ( less smoke ) and it also lubricates better due to high tech synthetic ingredients. Something like Klotz synthetic oils.
asw7576 is offline
Old 09-15-2005, 07:11 AM
Originally Posted by asw7576
Castrol oil ?
Castor oil.
I know.... I realized after I posted...
TC3 SS is offline
Old 09-15-2005, 08:28 AM
Aphinity's Avatar
Castor does not stick to your parts like synthetic does. This is both good and bad. Ever opened your motor and seen a blueish tinge to the parts? This is residual oil residue inside, which means it's bonded to your parts and continuing to protect them. That's the synthetic.
I had some very high end drivers (team drivers mostly) tell me to use fuels like Tornado, which has 9% oil, pure castor oil. I ran it in my old OS CV, and it ran so hot I couldn't run the fuel. However, they swore up and down that this fuel will make the most power and make your engine run cooler than most. It is very expensive due to the castor content, so they said, since castor is expensive, supposedly, and synthetic is cheaper which they told me is why so many fuels use it.
I don't know what to think anymore. I ran sidewinder during the last race, and when I switched back to blue thunder (my old reliable), suddenly my engine ran a whole ton better, even though that gallon of fuel is over 6 years old.
Bottom line? Everyone has a different opinion on fuel and the lubricants in it. All you can do is try it and see what happens.
Aphinity is offline
Old 09-15-2005, 08:37 AM
jrabbito's Avatar
Aphinity,
Tornado is a synthetic/castor blend. I use it for 1/8 onroad and get consistently lower temps than other brands...
You cant even compare it to blue thunder. BUT you must re-tune the motor completely when switching brands.
John
jrabbito is offline
Old 09-15-2005, 08:39 AM
stefan's Avatar
Sorry, but somebody told you BS. Tornado, which I'm running since I'm back in Europe has only 2% castor and 7% synth. They tried a blend w/o any castor last year and had some BAD results, so now they are back to castor.
Imho, the 9% overall oil content is way to low, the wear on my engines is horrable.
I'm now switching to custom blend fuel with 8% synth and 4% castor, like I ran in the US.
stefan is offline
Old 09-15-2005, 08:51 AM
jrabbito's Avatar
stefan,
1st you are lucky...the quality of fuel in europe is much higher than here. But you have noticed alot more wear with Tornado? Compared to what fuel? I am interested in this as I run Tornado.
John
P.S. I have been VERY happy so far with Tornado?
jrabbito is offline
Old 09-15-2005, 08:54 AM
asw7576's Avatar
Why you have to add more oil if you already use good brand of fuels ? Tornado, O'donnel, Byron, those are good fuel. Adding more oil also means less power and more pollution, am I right ?
I'm using O'donnel 25% and Tornado 25%. Tornado runs cooler, but O'donnel runs cleaner. I switch between the two, see no problem whatsoever.
asw7576 is offline
Old 09-15-2005, 12:52 PM
dct147's Avatar
hi guys, 1 side question.
how do u guys know the percentage of oil in your fuel?
i`m running blue thunder 25% and it doesn`t state anywhere on the bottle about the percentage of oil content.
dct147 is offline
