Serpent 960....
#661
Originally Posted by Julius
In stead of putting the nipple on the side insert a 3mm grub screw in both holes, and drill a 2.5mm hole in the back of the cap and thread the nipple in there.
Do a test. Easy to do. Blow air into the either the exhaust input or fuel output and air should come out the other hose. If it doesn't, you haven't drilled enough. How much to drill? The inside of the cap is hollow so keep drilling unit you reach this hollow space. If you use an electric drill. Go slow. I saw someone drill too much and scar the front of the lid. If this happens, the lid is useless. You'll need a new lid or tank.
As for plastic debris polluting the fuel supply, I don't believe this is possible. Exhaust gas flows through the nipple and into the lid. The lid has a membrane which traps debris. Pieces of plastic are too large to flow out.
Why doesn't Serpent make this option (centre fuel nipple) available?
#662
Originally Posted by C Verano
You have to hit something pretty hard to bend them.
#663
Originally Posted by nefastseven
hello another problem
has anyone have a problem with side plate L carbon(903132)?
when my engine(RB C5) is on the chassis,i can't put the side plate because the engine touch it with the crankcase backplate's screw
what the solution??
i'm going to bore the side plate where the screws touch...
what the solution??
#664
#665
Originally Posted by slide_228
If you cut the left hand stiffner, then u will need to remove the right one becuase it will make the chassis to twist unevenly. It is a subtle difference and yr chassis wil last longer.
#666
ok thank you
i did that this morning and all seems ok
I removed the stopper of the tank, and then I removed foam, there is also a small part out of plastic which is dismounted, that allows to see whether the hole is made
here is my work with the pressure
#667
ok thank you
#668
yes the car is ready,i did all tips i could read in this post
i just have to paint the body,and buy fuel.....but in Paris we have rain and cold weather,it's not easy to run before March
#669
#671
Originally Posted by Rookie Solara
Is Barry Baker running for 1/8th Serpent 960 at Winternational...? I don't think he is but I wish he is.....
#672
Originally Posted by captian
yes he is just like the nationals with the 960
#673
OH nice...........another big gun for the snake, the reason I asked is I saw his pictures of him wearing AE shirt, does he need to change shirts everytime when he is running 1/10th 200mm and 1/8th in between...?
#674
I'm sure he was wearing the AE sweatshirt because it's freezing there. When the racing starts, he'll have his Serpent gear on.
#675
Cool....someone should give him the Team Serpent Sweatshirt....and I just found out he is only racing 1/8th, no Touring for him.
