Kyosho Evolva 2005
#152
Originally Posted by Steven Jackson
Hi Rich
Any word on the rear way bar and new pulleys . I would like
to add them to my Christmas list.
Merry almost XMas! Rear Sway bar assembly and aluminum pulleys will be ready late January. A new batch of radio trays supports are being finished.
We are making a "deck height" gauge. It is an accurate measuring device for determining your piston and head button clearance - no more funky solder. Now, when you start moving the plug element you'll know why. A must have if your extracting the most out of you motor - or, you just want to protect your investment. I wouldn't function without mine. Available in three weeks. Based on a precision depth gauge - the trick - it is turbo plug enabled.
#153
Registered User
Thanks Rich I will look for the new parts in Jan
#154
Registered User
What's up Rich P how's the family. I will be at the sedan nats
that will be the only sedan race for me in 06. 1/8th will be
my focus for most of 06.
#155
Rich - I'll get Swayze RC to order me a Couple of Sway Bars and Pulley Sets for my DELTA / KYOSHO cars. The Ontario 1/8 On Road Racing Club is having a Promotional / Clinic Meeting with a Concours on Saturday January 14th in Hamilton Ontario Canada. It would be great to have these new products on my car to show the area racers.
Thanks for making these products available to everyone.
#156
#157
Registered User
Has anyone had problems with the 05 tank seal leaking. If
so how did you fix it.
#158
Hi everyone
Could anybody tell me were to get the 05 update kit and belt tensioners from please.
Im used to driving a V1RRR so any advice for a first time 1/8er would be great.
#159
2005 Upgrades
Originally Posted by V1R racer
Hi everyone
FM510B, Tank
FM507B, Front Bulkheads
FM545 Front Arm Set
(4) BRG008 Bearings
(4) VZ 213, Bearing Cams
FM508B, Rear Bulk heads
FM407B, Brake Lever
FM544-45 Spur Gears
FM543-49 Spur Gears
FM541-20 Pinion Gears
FM540-16 Pinion Gears
I didn't list the new "front sway bar" parts
The gears are much better - don't let the supplier send the older gears - the new gears are much beefier.
We have front belt tensioners - see: empirercracing.com
plus, there is an exploded view of the '05 with part numbers - for reference
I see you are in the UK - have you checked with: http://www.benracing.co.uk
hope this helps,
Rich
#161
the suspesion pins are supposed to be different
#162
Rich, thanks for posting up those part numbers for everyone.
#163
#164
Hi
Are the tyres for the Serpent 960 and the Evolva the same? Will Seperpent tyres fit on the Evolva?
