Serpent 977 Viper
#1081
What I see there is this tool http://www.serpent.com/product/1462/ but I can't find it no where..what other tool can I use?
https://www.amainhobbies.com/arrowma...490030/p441402
#1082
It looks like it might be discontinued. I have one of those tools had it many years. This is a good equivalent. I wouldn't recommend using pliers at all as it can deform the adjusting nut. In a pinch you could use small circlip pliers and insert the tips into the adjusting nut and rotate that way.
#1083
https://www.amainhobbies.com/hudy-cl...182005/p201086
#1084
Yes that is very surprising!! The arrowmax one looks cooler though
#1087
Just put a 2mm Allen driver through to hold the clutch bell. Wrap the pinion with a rag and then tighten as much as possible. It won't fall off. If you have the proper pinion tools it's much easier.
#1088
It doesn't last very long. You'll see the wear occurring on the drive surface. The standard steel bell with yellow shoe is more than acceptable.
#1090
The Alu bell doesn't last long regardless of the shoe. If set correctly the yellow shoe lasts a very long time with the stock steel clutch bell.
#1091
hi all any setup tips to make the rear slide more prodictably from turn in to apex
while still keeping stable on the brakes and with out making the steering too
twitchy my setup is the same as mark green halifax exept standerd oil/pistons
and red rear springs/green fronts
thanks rick..
thanks rick..
#1092
thanks rick..
thanks rick..
#1093
thanks rick..
thanks rick..
The rear is very soft for the 977 that will make the car very unstable and will not remain predicable / consistent. Especially on that washboard Halifax! As nitrodude says if your not running the same shock/spring package as Mark then you are not running the same setup! In my experience Marks setups are on the money for the UK tracks. He is also a very approachable and helpful guy. Did you go and speak to him at a national meeting at Halifax? If not why not? He is a factory driver and part of his job is customer service
#1094
the setup i'am runing at the moment is a result of testing and chating to some
of the serpent team which are very helpful guys.as i'am new to 1/8 onroad just
trying to increase my knowlage of this car to make better setup choices and
make testing more preductive geting the rear more predictable is the main area
in which i'am most struggleing and would like to here from club racers as well as
top pro's
thanks rick..
top pro's
thanks rick..
#1095
top pro's
thanks rick..
top pro's
thanks rick..
