Mugen MTX-4
#7171
hmm
Originally Posted by blanks596
I too, haven't ever experienced a blown spur gear and I've never replaced my gears due to wear on this car and I make use of all of them regularly. I currently use a skyline 1pc mount, and I loctite my screws. I'm using one of the original MTX-4 kits that came with 23t/24t pulley gears and my chassis has a nice tweak to it. I know some people like to play with the teeth spread, but I stay with 6 tooth spread, and I've never had any problems using the alum pin gear. In regards to chassis flex affecting the gear mesh, you've really gotta be aiming for the wall to flex the chassis that bad, especially at that spot.
#7172
I had never busted a 2nd gear till the other day when I did 2. I have a 4mm chassis, perfect mesh, no end point issues, etc etc. What I did find however was that I had a 0.6mm gap from the 2nd gear shoes to the 2nd gear housing. I am pretty sure that this was this issue as I have never had a problem until recently.
Will report back once its tested.
#7174
hmm
Hey red shirt, have fun at the Winter Nats
#7175
Originally Posted by asw7576
Sometimes the centax or clutchbell actually touch the two speed adapter. If they do, I could only suggest to increase the pinion gears by 1T on both pinions
#7176
What gap are you going to set it to btw.
#7177
Originally Posted by Artificial-I
Thats a very good idea using the digital caliper on that gap! I never thought about that. Will for sure do that when assembling.
#7179
Originally Posted by Canuck
Getting ready for a new season here and I have a question re. front diff vs solid spool.
I never tried a spool but would liek to know if it would be better for this track ?
As for oneway, just too difficult for me at this point.
I think you will find the car to be a lot easier to drive and the locked front will allow you to brake later and still stay on the line.
#7181
Anybody know what to improve car handling after minutes 25 ? I have serious handling problem after 25 minutes racing. ( I still have 20 minutes to go ). The car become unstable especially off throttle while doing tight cornering. The grip from rear tires is unbearable .
Thanks for your suggestions.
( I find out WHEN rear tires become same size like front, the sucks handling will occur. )
#7182
#7183
37 shore, 4mm split. ( 61 front - 65 rear ) and 24T side pulley.
Is it helpful to switch 25T front side pulleys ?
#7184
