Mugen MTX-4
#4651
Originally Posted by dienem
do you really need an engine starter or can you use a pullstarter for the mtx-4
No more room between engine backplate and the belt.
#4652
There are only 9 bodies approved by ROAR for .12 fuel racing as of now and Kawahara has none in the approved batch.
1/10 .12 FUEL TOURING HPI 7484 4-1-2007
1/10 .12 FUEL TOURING PARMA 10087 8-5-2007
1/10 .12 FUEL TOURING PARMA 10219 1-10-2009
1/10 .12 FUEL TOURING PROTOFORM 1461 9-1-2006
1/10 .12 FUEL TOURING PROTOFORM 1466 3-15-2007
1/10 .12 FUEL TOURING PROTOFORM 1468 3-15-2007
1/10 .12 FUEL TOURING PROTOFORM 1475 8-5-2007
1/10 .12 FUEL TOURING PROTOFORM 1477 6-30-2008
1/10 .12 FUEL TOURING TRINITY REF1102 6-22-2006
Huse, get ur shiz ready fo the nats...see you monday night playa hit me, dawg.
#4653
Originally Posted by going4#1
Does anyone know if you can use Kawahara bodies at a ROAR event? I saw one list but Kawahara isn't on it. Have things changed? Who is Kawahara's importer for the US?
#4654
I have Futaba S9451 digital servo. Lately the humming noise is really loud. Anyone can hear it even from 4 meter away The servo is still moving and the torque is there. Is this good or bad sign ?
#4655
Servo's usually only hum when they are searching for neutral position.
If the steering is tight it may not actually be returning to full neutral. Try gently moving the servo horn with your fingers to see if the noise goes away or reduces. If that doesn't solve the problem, it is more than likely internal.
If you are good with electronics, pull the servo apart and clean and relubricate the gearbox, and also check the servo motor that nothing is hindering it's operation.
Apart from that, use it til it dies, then fix it or get a new one.
#4656
Originally Posted by rmdhawaii
Just FYI, IFMAR approved the Kawahara bodies for this year's pre-worlds: (http://www.ifmar.org/pdf/IFMAR200mmbodylist1jan05.pdf)
is it another orginisation like ifmar or efra?
#4657
#4659
Originally Posted by itchy b
thank you Speedbug for the info link,
seems that femca is the regional controlling organization under ifmar, if i got that right, sorry but i have to ask, where does efra come into it then?
#4660
Be extremely helpful if the sanctioning bodies could have more compatibility with each other on rules. I just finished my first ever international event (Asian Mugen Cup) and all I can say is RC sure seems to be pretty much the same everywhere. Same tools, cars, engines, starters, rechargers, driving techniques, etc. Even the asshole drivers drive the same.
#4661
#4664
definately CVD's are a must have. apart from that I have replaced alot of the carbon fibre with the 3racing silver carbon, purely for looks.
