Mugen MTX-4
#4156
Originally Posted by gonzo416
where can i get these kawahara aluminum hexes with the 1mm offset?
#4157
#4158
Originally Posted by Joe Os
Why you using 1mm offset if you can adjust your track width?
#4159
New mtx-4
I have just bought a mtx-4. I will be running it on a banked oval track. can anyone help me out on a set up or what kind of hop ups are needed for the car.
#4160
#4161
even if track width is adjusted the rims are too close to the c-hubs and if the car hits something the rim is destroyed.
#4163
Originally Posted by THE DOCTOR
What is the narrowest that you have ever ran your front end and still liked it that way??
#4164
I have run mine around 196-197 and it was ok. Much more steering. You need to run the rear a little narrower too though. Rear shouldn't be more than 2mm wider than the front in my opinion. On tracks with a lack of traction this is a way to make the car feel like there is more than there really is. For a really stuck track, you wanna run it about as wide as you can get it though to avoid the dreaded "traction roll."
#4165
#4166
Originally Posted by Chris West
well the in field is similar to my track but with a longer straight by looking at the track the 1st gear might be a bit low but you would have to see on the track
but by looking at it if i was to go there i would take 17/59 or 16/59 and 23/53 or 23/52 (due to the long straight),
I prepare two cars : I'm going to test them on saturday
mtx3 with 21/58 and 27/52
mtx4 with 21/59 and 27/53
#4168
Originally Posted by Scott Fisher
mtx 3 and 4 use different pinions and clutch bells. If you try to run the same ones, your gearing will be way off.
I guess I'm the first to test very low gear ratio
#4169
#4170
ignore that last post
