Mugen MTX-4
#3136
Hey guys got a quick question for you mtx-3 to mtx-4 owners. Whats the difference between the clutches , if there is any? I have a mtx-3 clutch setup for my r40 , but was wondering whats the difference on the mtx-4....and do they swap back and forth if anyone has tried that.
Thanks.
Thanks.
#3137
Thanks.
Thanks.
If you run fine with mtx3 clutch... then stick with it.
#3138
Thanks.
Thanks.
#3139
Originally Posted by Scott Fisher
I have almost 3 gallons of fuel on my car. I just had to replace the side belt which is rubber. I replaced the front and rear urethane belts just because I have a 60 minute main to run tomorrow. They both look brand new. I don't know if you do this, but I never use denatured alcohol, or anything else for that matter when cleaning my car. I just use compressed air. I put on a set of the rubber belts as they definitely roll better than the urethane belts.
#3140
I have only raced on prepared surfaces. The only tracks that my MTX4 have been on so far are the Silver Bowl Raceway (las vegas), Revelation Raceway and Crystal Park Raceway (both in southern california). As I said, they are all clean and prepared dedicated raceways. Perhaps a dirtier track is causing your belt cracking? It doesn't sound like you are having any major issues, as belts do wear out no matter what you do.
#3142
Originally Posted by Tag
whats your opinion on alum side pully ? my 24T went out on me today and i am thinking about if i should go with alum or stay with plastic. some said stay with plastic as alum does not last as long , what do you think
stick with plastic. alloy wears out, and it's heavier.
#3143
Originally Posted by THE DOCTOR
What is the part # for the rubber belts?
Here is a complete parts list/orderform has all the parts numbers
#3145
Originally Posted by asw7576
mtx3 and 4 have big difference in clutch bell ( 2 bearings vs 3 bearings in mtx4 ), flywheel ( different depth ) and pinion gears ( more teeth vs less teeth in mtx4 ). So they are not switchable.
#3146
Originally Posted by Racing4Evo
I run at Revelation and broke my first side belt after a gallon or so. It just flipped over on itself and started to crack. I didn't hit anything. I think the side belt is too loose.
If you are worried about the side belt being too loose, use the 25t pulley and just adjust your tire split.
#3147
