Mugen MTX-4
#2836
I was told my Mugen that the Kawahara bodies had been submitted to ROAR, but I don't know if they will be approved before the Winternats.
#2838
Centex Clutch Adjustment
Hi everyone!
May i know what is the suitable adjustment(e.g. type of clutch spring,adjustment nut length,type of clutch shoe and clutch bell clearance)on a huge and open track and on a small and tight track?
#2839
Trader Rating: 27 (100%+)
no one other than mugen brings the kawahara bodys over seas.
#2841
Originally Posted by MTX4
Hi everyone!
Super hard spring
9.35mm from the top of the shaft to the nut
Gray shoes
Lightened centifugal shoes
.4mm gap
OR
JP spring
9.1mm from the top of the shaft to the nut
Gray shoes (red clutch shoes with JP aluminum bell)
.4mm gap
As for the different tracks, too many variables; length, traction, 2-speed shifting point, etc. Try these first and adjust as needed.
#2842
Drove my car yesterday for the first time. Overall I like the car. Traction was low but still the car was much more managable to drive than my V-One RRR under similar conditions. I'm going to give the car a full rundown today. It's a litle lazy compared to the Kyosho but I think that suits my driving style better cause I'm not that smooth of a driver.
#2843
hehehe..... the gang got bigger
#2845
#2847
Originally Posted by Scott Fisher
Uriah:
What setup do you have on your car. I may be able to give you a few suggestions. Also, do you need more on power steering, off power, or both.
I am using 37's all around.
rear hinge pins all the way down(I usually use this with low traction, up for high traction)
front pins all the way down
30K rear diff oil
kit shock springs
600 wt shock oil
no shims under camber link rear---middle hole inboard camber link
rear camber -3.5---2.0 front
-3 rear toe
-1 front toe
23 tooth pulley
I will play with it more when I get to FT Myers(high traction)
Basically a stock setup, any suggestion are appreciated.
#2848
Another time here.... (Oh noooooo!!!!!!!!!!!!)
Hi all:
Long time without posting (just after WNats '04), but still see many well known ones.
Two weeks ago unpacked another time y '3' and gave some tanks and noticed there's a '4' there and said.... Need one now!
Anyway... Have some pieces for the car (in fact I'll pickup tomorrow of the store). Teflon brake pads and one brake rotor (Ennetti rotor). Heard of the blue brake pads... anyone uses them? what's on them regarding the black ones?
Sheeeesh! that thread game me some hard time reading the 95 pages of posts, taken some notes for the forthcoming build. Show pictures in next days.
#2849
Originally Posted by Corse-R
Hi all:
#2850
Originally Posted by Grinder
The car had a bad off power push, and slightly loose on power. When I tried to push the car on power it breaks loose. I think this is mostly due to low traction.
30K rear diff oil
kit shock springs
600 wt shock oil
-3 rear toe
-1 front toe
23 tooth pulley
30K rear diff oil
kit shock springs
600 wt shock oil
-3 rear toe
-1 front toe
23 tooth pulley
