fw-05r - brake linkage problem ??
hey just a question regarding my brake linkage
i have it set up like the book however after i apply the brakes and then throttle, the car feels like the brakes are still slightly grabbing i also tried leaving the bolts that screw the brake pads into the center bulkhead a bit more looser to help overcome surely this cant be normal ? what can i do to overcome this thanks heaps john |
Hi
Make sure the brake pads are not catching on the bolts holding them on, or check the brake piston returns and does not stay out after the brake is let off Hope that helps |
yeh looks like the brake piston doesnt fully return after i throttle again
what could be the cause of this ? |
I've always thought it was the brake disk catching on the end of the pins.
What I do is to run an extra brake pad back plate which pushes the brake disk up the pins a bit more. Had the same problem with the V-one R when I had it. |
Re: fw-05r - brake linkage problem ??
Originally posted by mrgsr hey just a question regarding my brake linkage i have it set up like the book however after i apply the brakes and then throttle, the car feels like the brakes are still slightly grabbing i also tried leaving the bolts that screw the brake pads into the center bulkhead a bit more looser to help overcome surely this cant be normal ? what can i do to overcome this thanks heaps john put them on the middle between the 2 brakepads.;) :nod: cut the spring for desired length.:nod: :) :D :D this is a 100% works!! |
that sounds like an awesome idea!
thanks heaps ill try it out |
