DSM SPECTRUM 2.4 GHz Radio system
#61
Originally posted by joemugen
doug,
did you just get yours? where did you get it from?
joe
doug,
joe
#62
i just bought one from fast and furious. i am a tad concerned now. is there a way i can tell if it is bad from my home?
#63
If there is a problem, you know right away.
#64
Give it a good run around the yard for a bit, you'll notice certain parts of its range the receiver won't respond or the signal seems laggy. I have a 3pk with the spektrum module/receivers. I tried all 3 of the receivers I bought, all did the same thing. Throttle response was laggy at times then it would loose signal all together on steering and throttle.
I contacted them and was told to send everything back in for an update. It's ok though, once the kinks are worked out this setup will be perfect!
#65
I wonder what the percentage of bad ones versus good is.
I did get an email (finally) saying that the receiver has been repaired and has been shipped out. So I should have it for our first off-road race day
