Serpent Cobra GT >
Serpent Cobra GT
Like Tree99Likes
Serpent Cobra GT
Old 03-18-2014, 06:49 AM
  #931
emacrimes's Avatar
Does someone knows if there would be a problem putting in am S811 center diff on the GT?
We run in a small track, no 2nd gear needed.
emacrimes is offline
Old 03-18-2014, 07:44 AM
  #932
Pit-racer's Avatar
Be careful Andy. My car will make His debut at SWCS #2. I'm getting everything in line.
Pit-racer is offline
Old 03-18-2014, 12:25 PM
  #933
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by TerribleTy
There is a fuel filter inside the tank, that one should be more than adequate. As far as filters from the exhaust I personally don't run them but I have seen some people with them. I tried those inline fuel filters and they ultimately just give you one more area for a potential air leak making tuning lots of fun. Fresh tubing and the already installed filter should be solid. Look inside the tank you'll see the filter I am talking about I think its called a clunk filter.
+1, if its not needed dont use it or it will fail
MantisWorx is offline
Old 03-18-2014, 03:49 PM
  #934
You will need a new clutch bell and I would use the center diff from the buggy. I just went and checked my buggy and the center drives are longer as well. 102 and 105. I would assume if you are using the buggy stuff you would need those as well.
If you can wait till tomorrow I can test the diff out and tell you how it fits. I have to head into work now.
TerribleTy is offline
Old 03-18-2014, 07:35 PM
  #935
emacrimes's Avatar
Ok, i'll wait.
Thanks!
Let me know what part numbers should i get for the GT to make like a buggy. (1 gear)
Old 03-18-2014, 08:08 PM
  #936
Ok, i'll wait.
Thanks!
Sounds good, I'll dig into this in the am. I work all night long
Are you wanting to run the center diff locked or with fluid? May be fun to try it with a functional center diff but that only adds to setup. We run very short tracks in Utah as well they make you drive no doubt.
What kind of motors are you running? I know a few short track monsters I use fro racing around here.
Old 03-19-2014, 05:29 AM
  #937
Pit-racer's Avatar
Originally Posted by Pit-racer
O.K. big question here .... install fuel filter? Or cooler? To carb or from exhaust?
O.k. so I won't use anything cause it's not needed just eye candy.
Old 03-19-2014, 11:59 AM
  #938
Ok, i'll wait.
Thanks!
Okay so I have the one speed in my car. Looks like you are going to need...
102mm for the center front driveshaft.
Differential cover for the buggy
The correct clutch bell. Not really sure what tooth depends on what you decide.
Looks like you may have to do a little shimming to get the single speed to fit nice and tight between the 2speed mounts as the differential is a little shorter than the 2speed by maybe 2-3mm.
Seems like it will work with the parts above but that is just my opinion. I'll post you a pic when I get back home.
Old 03-20-2014, 06:41 AM
  #939
emacrimes's Avatar
I have a Speed in it, about the diff i prefer it to be with oil.
Thanks, i'll wait for the pic.
Old 03-21-2014, 12:46 AM
  #940
Sorry this took me so long... So much stuff going on for me right now lol.
So here is why I mentioned getting the longer front drive shaft.
Front = Right
The front driveshaft pins are too close to the end of the cup in my opinion. I would bump it up to the 102 and be safe. Other than that the parts I listed above should do the trick.
Old 03-21-2014, 08:10 AM
  #941
emacrimes's Avatar
Front = Right
Dont worry and thanks for taking the time to do it.
Do you know the 102mm drive shaft part number?
Old 03-21-2014, 10:39 AM
  #942
scary_jerry's Avatar
Default 102mm 'bone'
An 'internet' question initially only hit on a '112mm' but a European site came up with (after translation)........102mm..........'center front V2 Serpent 811 2.0'..........(600509).
scary_jerry is offline
Old 03-21-2014, 11:27 AM
  #943
Thumbs up
Right on the money Thanks Jerry!
Old 03-21-2014, 08:49 PM
  #944
*1speedy's Avatar
Here you go
http://www.absolutehobbyz.com/produc...ducts_id=10598
*1speedy is offline
Old 03-23-2014, 07:12 PM
  #945
Pit-racer's Avatar
Do the werks lite wgt. clutch work well in the cobra, or is the stock clutch just as good. It worked flawless in my K igt2 for years.
