Like Tree1Likes
Lab C-02
Old 01-03-2018, 06:25 AM
  #571
British Menace's Avatar
Hey,
Could anyone tell me please if the Brake Disk and Pads from the CO3 fit the CO2?
Thank you.
Regards
BM
British Menace is offline
Old 01-04-2018, 09:49 AM
  #572
Originally Posted by British Menace
Hey,
Thank you.
Regards
BM
Anyone?
Old 01-04-2018, 12:49 PM
  #573
Anyone?
Call Target rc
Capricorn 802 is offline
Old 01-04-2018, 01:51 PM
  #574
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
I see no reason why it wouldn’t fit since the transmission has been virtually unchanged
Serpent-Dan is offline
Old 01-05-2018, 07:48 AM
  #575
Originally Posted by Capricorn 802
Call Target rc
Good idea.......
Thankyou
alxfnts likes this.
Old 01-05-2018, 07:49 AM
  #576
That does make a lot of sense. Thanks
Old 01-09-2018, 01:50 PM
  #577
DS Motorsport's Avatar
Hey,
Thank you.
Regards
BM
They fit. You also need the bushings and the springs which go between the pads.
DS Motorsport is offline
Old 01-10-2018, 05:55 AM
  #578
Thank you. I haven't ran this car since 2013/14. What was the hot set up? Infact. I haven't ran 1/10th Nitro since then??!
Regards
BM
Old 01-13-2018, 09:38 AM
  #579
Hey
I have a 6 hole piston in the standard shocks. I was going to start out at 1000cst oil. Do you think that's a good starting point for a well prepared, med' grip parking lot track?
Do you find the "newer" big bore shock on 2 hole pistons would handle 600cst? ...... a good starting point for them?
Thank you for any help you can give.
Regards
BM
Old 02-16-2018, 11:00 AM
  #580
snuvet75's Avatar
Trader Rating: 16 (94%+)
If it's medium grip, 1000cst should be fine. I find that a bit thinner rear oil helps for more stable car. So do the softer rear springs of course.
By the way, didn't realize C02 had 6 hole pistons. That's sort of crazy. What mm are the holes?
snuvet75 is offline
Old 02-17-2018, 10:11 AM
  #581
I would have to check but I'm prity sure they are 1.2.
I have a set of the Big Bore shock's too. Not sure weather to use them instead?? They, at the moment, also have 6 hole piston's in too.
Thanks for answering either way
Regards
BM
Old 02-18-2018, 05:44 AM
  #582
Ok. So, to any of you more experienced Capricorn driver's.
What is the difference between these two shock piston's ......
"Big Bore 3 Hole shock piston" .... CAP-18506-3
and
"Big Bore 3 Hole shock piston" ....... CAP-29152
Does this have something to do with the different version's of Big-Bore shock's that are/ have been introduced? (ie: Version 2 and Version 3)
My obvious question here is .......
Will both piston's fit all the version's of the Big Bore shock's?
Regard's
BM
