Races
Quick Question? when it comes to racing, heats, main, and qualifiers. I'm not sure how or what do they look for when you are racing for the qualifiers what is or is there a standard? and then i know that the fastest drivers then go into the A main and then if theres alot more drivers b main, etc. But what is involved in the qualifiers race, heat races, mains, etc. its been a long time since i have been on a track but we did it alot ALOT differently way back. i need someone to help school me, i might be out with Glenn and his club this weekend so i would like to get some pointers, i dont want to be the newby causing problems at the track because i dont know!!! know what I mean.....
Adam
Adam
It's pretty simple really. Heat races are run to set the order of the main. It is all done on your time so most if not all races you are racing against the clock until the main event (IFMAR style). If you run in a large class or at big events it is very likley that there will be A, B, C and so on Main's for each class. The winners of the lower mains bump up into the higher mains.
Not real hard to understand and the track will guide you through the process.
Go out and have some fun !!!
Drivers are seeded into heats, where we race the clock and not each other and rotate start positions from pit lane, then after the 6 rounds, the top 4 qualifiers are seeded into the A-Main. From there it's a bump up system of grid starts based on qualifying position for 1/16th 1/8th 1/4 and semis with top 4 progressing up wards and in semi's top three finally filling the remaining 6 positions in the A-Main final. Might have it a bit wrong in bump numbers, but a great system in my opinion. Everyone has a chance to make good if they had a hard time in their heats of quals
Electric EP use different systems.
Its the most laps in 5 minutes. He meant he did 17 laps in 5 minutes, but wished he had done 19 laps in 5 minutes.
So total time + laps completed set the grid order for the finals
