Clutch Nut Help!!!!!
Hey i just wondered if anyone knew what the adjuxtment of this nut should be, pictures as follows. the clutch sits between the 1st and 2nd spur gears and changes from 1st to 2nd. Cheers Guys
Start off with 4 turns out from fully in - if it sounds like it is revving high and going slow, take it out 1/2 a turn and try again. Once you hear it hitting 2nd, then just fine tune it.
i know what the part dose just kinda need to know what the adjustment should be. Thanks
