Velox V8 ´11 spyshot
#151
Suspended
We mounted the transponder on top of the receiver casing but I also see it mounted on the steering servo (outside).
#152
Great,thanks for the info!
#153
Sorry for my late reply, have been a bit bussy. It seems to me that your rear end is too much locked and jumps free at the end of a corner. You could do several things:
Further one general remark, about 95% of all Velox drivers drive 32FR/35RR shore. If you deviate from that, it could result in a different tire wear / changing the tire split. E.g. more front wheel drive, e.g. spin out.
- Try to set more chassis roll, put the front upper arms down and add 1mm sims up the top of the rear uprights.
- Put your body to 23 - 25mm in front of your bumper, it reduces rear grip
- Set the lower rear arms to mid. This is the general position for medium to high grip tracks.
#154
radio tray flex bearings
Can someone help me locate replacement radio tray flex bearings for the VeloxV8 '11. The manual shows part number 79-03-06B, yet I have been unable to locate this part at any of the suppliers. They are identified as 3x6x2.5 flanged. I have seen the hardware for the bearings,which is 72-03-06 m3x6 , but not the bearings themselves. Thanks in advance. Ken
#155
Suspended
#156
#157
Anyone going to provide parts support at the nats? Should have everything I need but would be nice to know that there is some backup.
#158
Parts for sale
Interested in parts check this thread:http://www.rctech.net/forum/r-c-item...ml#post9663372
#160
Does anyone know if someone makes aluminum front sway bar mounts for the 1/8th Velox? I've been toying with some modified pieces with graphite to stop the tips from hitting and grabbing the droop screws.
#161
#162
#163
Hi all, has any one got a gear ration chart by any chance. I cant seem to find anything for the v8 11 anywhere.
#164
Hey ProModels,
I added a gear ratio chart to our download section on our homepage:
http://www.team-shepherd.com/en/inde...d=24&Itemid=48
You find it at the bottom.
#165
Thanks Patrick ;-)
Hey ProModels,
