My nitro tc3 seems to overheat, help.
QUestion, my car kinda dies like after 6 minutes of usage, it does it everytime, seems like it is running too high. Is there any thing I can do to cool it down? Maybe its not tuned correctly?
do you have holes cut in the front windshield to let air blow across the engine?
theres a hole in the front and back window, 2" circle. It only dies when it idles. I was driving it, and I brought it back to check on fuel which was fine and then it died. happend twice.
Super Moderator
Re: My nitro tc3 seems to overheat, help.
Its strange, im new at this rc thing so I gotta read about it a bit. I could run it with out the body for a very long time, its just when the body is on that it dies.
Never run your car without a body!!!
I've never understood why some people want to run their car without a body. Noone else can see the da** thing, one, and two, it's not going to tell you anything you need to know. You can't set the carb. without the body. It shouldn't handle without a body, you need whatever downforce a body will give you.
If you have the new tank, and a good amount of pressure line you can get the temp where the engine will perform.
Trader Rating: 45 (98%+)
Try
Rich up your low end
Check your settings, retune the engine back to factory settings and make sure the pipe is not being blocked by the body.
it might die while idle because u have it too righ but if its over heating and its rich well idunno then. but i have my tmaxx real rich so it dont overheat and it dont like idling
shut up mx u r so totally wrong he knows nothing.
im jk
over heat?
Is it the earley design tc3 gas tank? Check and see if the presser line from the exhaust pipe comes out of the fuel cap or is it on the tank it self! If its on the tank then get the new design tank with it comming out the fuel cap. And get a Hellion1 body It's hot but it makes the car run cooler ...hope that didnt sound like advertising lol
