VHT traction compound >
Old 02-27-2004 | 05:08 PM
Grinder's Avatar
Default VHT traction compound
What do you dilute VHT with to to spray it on the track? Some people say alcohol, I want to use water. Help.
Grinder is offline
Old 02-27-2004 | 05:15 PM
Roger's Avatar
grinder: use gasoline 50/50 mix. If you want it to be real sticky, use 60/40 ( VHT to gas ). If you really want to save alot of money for your track, but a whole drum of VHT. It'll last you the whole season
Roger is offline
Old 02-27-2004 | 05:58 PM
richey's Avatar
Methanol is what works the best and it is stable.
richey is offline
Old 02-27-2004 | 06:39 PM
popsracer's Avatar
Grinder;
DO NOT use gasoline to dilute your VHT.
Gasoline will attack and damage the asphalt and unless you own the property, NOT a very good idea.
Methanol at 50/50 is the standard for dilution of VHT.
popsracer is offline
Old 02-27-2004 | 09:19 PM
coldeye's Avatar
Pops is right, the gas will eat up the asphault or slurry and you will end up with gravel and holes. Could work on concrete though!
coldeye is offline
Old 02-27-2004 | 11:28 PM
Roger's Avatar
thats right. I forgot to mention that. Thanks pops.
Roger is offline
Old 02-28-2004 | 01:04 AM
Speedie's Avatar
I did alot af research into VHT and methanol is definately the way to go. And yes buying it by the drum cuts the cost in half.
Speedie is offline
Old 02-28-2004 | 02:59 AM
I would have thought the biggest question when considering anything to do with VHT is do u REALLY want it at all .
Dexter is offline
Old 02-28-2004 | 07:35 AM
Can somebody please post some links to VHT information?
Where is it sold?
Price?
Characteristics?
Will it work on 60 deg. celcius (140F) asphalt?
Thank you
Fernando_M is offline
Old 02-28-2004 | 12:24 PM
http://www.vhtpaint.com/trackbite.htm
EJRacer is offline
Old 02-28-2004 | 03:20 PM
Speedie's Avatar
If you have raced with and without it, or worse on a track sprayed with soda. The question would be how can you race without it?
Speedie is offline
Old 02-29-2004 | 11:34 PM
The problem i have herd many times is that there is only a very small line left after being sprayed and this is usually laid by the 1/8th scale cars and if u get off this small line it's horrible. This is the problem for NT because the 1/8th line is not conducive forthe NT's.
Dexter is offline
Old 03-19-2014 | 04:22 PM
Manny Fresh's Avatar
VP sells it Lane Choice 7 (LC7) and Methanol (M1). If you buy a
5 gallons of each and use 50/50 you should be good. I've purchased it for $133.
Manny Fresh is offline
Old 03-19-2014 | 04:28 PM
wingracer's Avatar
Holy ten year old bump Batman.
wingracer is offline
Old 03-19-2014 | 04:32 PM
T-Hawk's Avatar
Or buy 55gal for $750
T-Hawk is offline
