Old 12-28-2009, 11:01 PM   #61
Originally Posted by lil-bump View Post
That's extremely light!!!
just wonder where to add extra 150g
Hobbypro / Team C, Hong Kong
www.hobbypro.com.hk
www.teamcracing.net
Picco, IDM, Werks, ATS, Shepherd, Blue Bird
hobbypro is offline   Reply With Quote
Old 12-28-2009, 11:09 PM   #62
wingracer's Avatar
Trader Rating: 24 (100%+)
That's also without body so it's not quite as light as that.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-29-2009, 06:27 AM   #63
Maddin21's Avatar
As I wrote before...our cars here over in Germany are 1660g ready to run with full set of tires right out of the box and of course with body.
100g underweight...that hurts :-)
--- MARTIN ---
Maddin21 is offline   Reply With Quote
Old 12-29-2009, 07:43 AM   #64
DS Motorsport's Avatar
That is really impressive, especially if you are still using a normal nimh pack.
Would love to run the car in the dutch championship, but I still have a brand new NT1 sitting on the workbench over here.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-29-2009, 09:18 AM   #65
--- MARTIN ---
If I remember correctly here in Germany our weightlimit is 1700g incl. PT...
So 40g underweight is nothing special!!
seb1109 is offline   Reply With Quote
Old 12-29-2009, 11:02 AM   #66
musti72's Avatar
Originally Posted by nico75 View Post
Hi all,
Here is a picture from Yome3000 with the weight of the car --> 1538g :
For sure, we can get some more lightness with low profile servos...
Season's greetings to everyone.
Cheers all.
Nico
Yes, very very light...
Some low profile servos would save 2x15grams, and the body should be around 100 grams so car would be around 1600gr range. Considering the car has a lot of aluminum parts, it couldnt be lighter.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 12-29-2009, 01:01 PM   #67
Maddin21's Avatar
40g underweight with full tires...
With tires run to the absolute limit and a bit of safety it's 100g...
Old 12-29-2009, 01:19 PM   #68
But what did Capricorn do to the car to get it that light?.
Because my NT1 is very lightweight as well (1590 with bare rims) but that took some real work to get it that light. For instance I run two low profile servos and a very light lipo (42 grams). And offcourse the regular Ti stuff and hollow axles.
But looking at the car I can't see where Capricorn found more pieces to safe weight on. Does it use the plastic and aluminum diff internals?.
P1-RC.com
Old 12-29-2009, 01:47 PM   #69
musti72's Avatar
It uses plastic diff gears(about 1/6 of xray gear weight) and light cross pins.
Mustafa Alp
Old 12-29-2009, 01:54 PM   #70
musti72's Avatar
Nico you have PM
Mustafa Alp
Old 12-29-2009, 04:31 PM   #71
Maddin21's Avatar
Diff gears are made of a composite mix material quite similar to the suspension parts. Diff axles are made from 7075 alloy. Rear dogbones and front swingshafts are of alloy (steel pin) and half the weight of the XRAY bones and shafts. Wheel hubs are one-piece of steel and machined to be light. Only the drive train saves about 35g compared to an XRAY whose parts are interchangeable with the Capricorn ones.
Clutch and gears are small and light.
The rear stabilizer rod is made of alloy.
Maybe that's the secret...or we should measure the chassis plate thickness...
--- MARTIN ---
Old 12-29-2009, 04:32 PM   #72
lil-bump's Avatar
Trader Rating: 83 (100%+)
That explains it. Now to see if they hold up. My bet is yes.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-29-2009, 04:47 PM   #73
rocca30's Avatar
hopefuuly the car is better than there motors?
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 12-29-2009, 05:35 PM   #74
--- MARTIN ---
Ok ok, now it's clear to me where all the weight saving comes from.
Hope the composite diff gears will last, haven't purchased them for my NT1 because I had my doubts about durability.
Btw as a tip to everyone who is running the capricorn car: check the aluminum driveshafts regularly. I used them on my Xray this year and one of the driveshafts broke on the last race. I was leading the race quite comfortably so it sucked.
The end of the driveshaft, which holds the pin, was completely snapped off.
So I would advice checking the shafts regularly.
Or replace them after a half season.
P1-RC.com
Old 12-29-2009, 06:48 PM   #75
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default drive shafts
I've seen some steel dogbones snapped in the same place like you said some parts need changing when you run alot of track time
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Capricorn1/10 Touring Prototype!!! bola Nitro On-Road 68 02-21-2009 06:53 AM
