Team Magic G4RS 2009
#1396
220mm conversion kit
Hi,
Ive run the G4RS now for just over 3 months, and changing from serpent i have dropped my lap times considerably ( which is amazing! ) really like the car handles like a dream and i havent broken anything since i bought it, only stripped one spur gear! where as the serpent kept breaking on me.
I was just wondering, i want to do the Sports GT class next year for nationals as i attended one national this year and came 3rd in the B Final and this was my first national and only been racing since feburary, loved the adrenanline and rush, but like the new 220mm class. Ive seen there is a 220mm conversion kit for the G4RS and want to give it a try its not to expensive and looks good, just wondering if anyone had any thoughts on this? if they are good, do they handle well etc.
#1398
220mm about to happen here too.
Cheers
Adrian
#1399
Where did you buy your kit from?, i cant source any from the uk so im gonna have to buy it overseas..
cheers
Lewis
cheers
Lewis
#1400
You could also grab one from http://www.rc-mushroom.com/
RC Mushroom also have the Lola Conversion Kit avaliable as well.
Cheers Ian
#1403
Well guys,
Last night had the time to check what happened, total disaster :
- Thrust Bearing GONE from centax : GONE
- 2nd speed gear got loose from its housing (those so-small screws really do the job ?), so at least one of the small screws got loose inside the 2 speed housing and got the 2 speed shoes all screwed, total destruction.
So, i was lucky to end the race on 1st gear actually ...
WHY this happened ?, no idea ...
cya,
cya,
#1404
Well guys,
cya,
cya,
Just wondering...
Do you use the standard (with mounting lugs) or Kfactory (no lugs) spur gears?
I guess less clutch end float next time!
Pip
#1406
Speaking of two speeds, i have recently picked up a second hand G4RS09 and the main shaft has me a bit confused. The end has a bolt in it and something like a thrust bearing washer (without the long shim neck) holding the gears on. I see in the manual that it's meant to have a circlip on the end instead.
I am wondering if the standard shaft has a 3mm bolt hole in the end or is this perhaps an aftermarket shaft?
The two speed housing is also so worn down its worn to the adjustment hole!! I didn't think it could wear down that much.... do they tend to wear out quick?
#1407
The housing sometimes touches the clutch bell and wears like this - bad design , however it looks ugly but will still work fine.
#1409
I've had a not so good last few days with my G4RS 09 as well.
I have had two major issues this week!
The first was a simple one... accidentally managed to "Snag" the Wire for my Battery which has resulted in my Car being "Posessed"... replaced this with a spare battery that I had until I get the propper time to sit down and warm up the Soldering Iron to replace the connection.
The second was I managed to spring a fuel leak from the engine which has spread some "lovely crap" all over my Brake Disc, Pads and Bulkhead (not to mentioon the rest of the rear end of the Car). My mate at the Local Hobby Shop finally located it after I had thought that it was just the fuel line. Turns out one of the O Rings in the Carby is shot... a neat little 10 Cent part... if that.
On the bright side though it has given me lots of matience time as well as opportuinity to pull down most of the car and ensure that everything else is working!
Lets hope that I am good to go for the weekend!
#1410
I was trying to get it clicking into second and wasn't sure if the edges of the hole were digging in a bit and keeping it in second. Maybe i didnt have enough room to click into second as i race at the track at Kambah in the ACT which is a fairly small track.
Have ordered a new one which was nice and cheap.
Had a bit of an altercation with the pit wall after i hit a shallow puddle and it went a bit haywire (full throttle slam!)..... i got lazy and didnt put a balloon around the receiver like all my other rx's especially since i have the holey rx box~
First few laps were awesome. It's now pulled apart waiting on some bits and a complete rebuild so i can get to know it better.
Cheers man~
