Team Magic G4RS 2009 >
Like Tree3Likes
Old 02-19-2010, 04:54 AM
  #1111
impalabob64's Avatar
Default On the way
Originally Posted by getpip
Hi all..
Has anyone found a LiFe rx pack that fits yet?
LiFe seems to be the way forward!
Hey all i got in touch with Tory from Skyrockets batteries, they will be one of my Sponsors for the 200 mm Worlds . He will be making those Life packs for the G4RS 09 an for my M11 Radio also, so check Skyrocket batteries.com
Bobby Watson
PS I,m Going to the Worlds
impalabob64 is offline
Old 02-19-2010, 06:27 AM
  #1112
getpip's Avatar
Bobby Watson
Cheers Bobby I'll check em out...
By the way .... Are you going to the worlds?
getpip is offline
Old 02-19-2010, 06:59 AM
  #1113
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Bobby Watson
PSS you had better send me them bodies soon or you will be driving the CLEAR car @ the worlds my friend lol
rcpaintinpete is offline
Old 02-19-2010, 02:04 PM
  #1114
GMartinez's Avatar
Trader Rating: 91 (100%+)
Pete if Bobby forgets he will get a chance to use a lot of stickers
GMartinez is offline
Old 02-22-2010, 11:35 AM
  #1115
Default Centax set for G4 RS II
Hi there,
Could anyone tell me where I can find a full centax for G4 II?
I notice that only sell by parts ex: flywheell, Clutch Nut...
And the the kfactory centax for G4+ is compatible for the G4 II?
If I can´t find a full set for G4 II?
Thanks.
T.Senna is offline
Old 02-22-2010, 12:24 PM
  #1116
Chickentrader's Avatar
Originally Posted by T.Senna
Hi there,
Thanks.
G4+ and G4RS08 clutches will fit the G4RS09. Most other parts won't. Just check that you can get the same pinions for the K-Factory clutch.
On a different note: We have just bought a new Shimo edition Kyosho RRR Evo, and it also came a brand new Kyosho designed flipper style clutch. The clutch proved to be useless as it would slip like all hell; no matter how little tension we put on the spring. There were no holes for extra weights in the flipper weights to make it grab more positively, and we ended up putting the same flipper weights between the pins; like a centax clutch, instead of pivoting on the pins. The result; the clutch works perfectly! Someone told me that this has also worked in some X-Rays that also use this clutch invention.
Perhaps this could be worth trying for those who are not happy with the G4RS09 clutch?
Kindest regards,
Lars.
Chickentrader is offline
Old 02-22-2010, 02:00 PM
  #1117
Trader Rating: 15 (94%+)
G4RS09 clutch works awesome
i use the standard clutch except i use the yellow shoe and the k-factory teflon flyweights, you can also use the sirio flyweights if they are easier to come by.
i set the adj nut to 0.6-1.0 depending on grip. .35 gap between shoe and bell and about .15 end play
mrgsr is offline
Old 02-22-2010, 05:29 PM
  #1118
Bundy_Bear's Avatar
Kindest regards,
Lars.
Lars:
Do you know if you use the RS08 clutch setup on the 2009 edition what clutch bell would you use... at a guess it would have to be 09 bell!
My girlfriend has claimed all my Team Magic gear and has her eye on my 2009 edition now... I made the mistake of letting her drive the G4JR running Luis setup and now the mini is collecting dust!
Thanks in advance
Andrew
Bundy_Bear is offline
Old 02-22-2010, 06:46 PM
  #1119
Trader Rating: 26 (100%+)
that's right the standard clutch with yellow shoe works great.
i'm looking to get the k factory lightweight flywheel and clutch bell
RANDY SMOOTH is offline
Old 02-22-2010, 11:23 PM
  #1120
Originally Posted by Bundy_Bear
Lars:
Thanks in advance
Andrew
I think that both clutch bells would work, but I'm not sure. Someone on this thread would probably know. To be sure use the clutch bell that the the clutch shoe is meant for.
Kindest regards,
Lars.
Old 02-23-2010, 05:02 AM
  #1121
Default Testing Completed
Well as you know i have been running the the full X-Ray clutch system in my G4RS 09,well another stroke (of im at home board lets try this) well i have found that the serpent 720 will work also,BUT you have to use the steel 1-piece pinions you know the $40 ones thats kinda hard to get.The pitch is a perfect match.The only thing i did was slot the holes on my engine so i could get the engine to slide back.Again this is what i do when i get the lets try this bug.The clutchbell from the 720 is the lightweight which is 25mm in size compared to the 28mm clutchbell from the 09.Just think of how much acceleration i have with this clutch system, with the bell being 25mm,Retarded.The 09 clutch is a great clutch system you know always got to try something.
Old 02-23-2010, 07:02 AM
  #1122
aizenbelle's Avatar
+1
aizenbelle is offline
Old 02-23-2010, 12:06 PM
  #1123
getpip's Avatar
I have to say I had trouble with the clutch when using the pivoting shoes. I shimmed, I adjusted, I changed springs... nothing worked...
I ended up cutting them down so that they floated between the pins (like the G4 clutch), after which it was great.
What do you guys get from the yellow shoe that you dont from the black?
getpip is offline
Old 02-25-2010, 05:55 PM
  #1124
alot more grip
Old 02-26-2010, 04:46 AM
  #1125
ALG
The K Factory parts on the clutch against the OEM on the kit are night and day.
I can say that the only way to go is yellow shoe and teflon flyweight with one weight. gap set to .40 mm
Have fun and keep tunning
ALG
ALG is offline
