Team Magic G4RS 2009
#1097
slop in steering ..
Hi Guys has anyone found where the slop is coming from in the steering?
its a pain in the ass trying to get the toe right, yuo can hold the servo then move the whole steering linkage side to side a couple of mm
i tried to replace the ballends on the steering linkage but no luck, i have also placed a .2 shim between the top deck and ackerman holder
#1098
#1100
Hey John
Either the servo saver isnt tight enough...
The internal sleeve and housing is damaged..
The Top or bottom bearing is loose..
Or the post is loose...
Cant think of any other reason why.
Oh.. maybe servo stripped a gear?
PS: Those bearings are tiny..
#1101
servo's
hey and hello to all im getting into onroad nitro and i have a team magic g4rs 2009 and need some general suggestions for steering and throttle thanks ,my home track will a basic parking lot style set up
#1103
Problem with shocks...
Hey guys ...
I noticed that my G4 RS II falls oil off the shocks ...
Anybody notices that yet?
What can I do?
What can I do?
#1104
Hi!
don't worry!
which Oring you installed inside your Shocks? Black or Gray?
If you have the standard black Oring, this is the problem! unfortunately are no good, TM made a new version of oring, and ar gray, these are perfect!
I hope to be helpful for you!
Ciao Ciao from Italy!
don't worry!
#1105
Slop
#1106
#1108
Ajustable Front Anti-Roll Bar Set
Hi ,
Has anyone tried the new front anti-roll bar from kfactory for the G4 RS 09?
IN TERMS OF PERFORMANCE IS VERY DIFFERENT?
Itīs better than the oreginal one?
#1109
I have one and used it once, havent had a chancet o really do some back to back tests with the original as the weather hasnt been so kind.
i did find it felt softer than the stock, and also it was so easy tos et the front tweak so that both arms lift the same left to right
#1110
Hi all..
Has anyone found a LiFe rx pack that fits yet?
LiFe seems to be the way forward!
