Old 06-10-2011, 01:48 PM   #3721
quietstorm76's Avatar
Originally Posted by dawin2122 View Post
Hi guys.Ok i need recomendations for starter box to my serpent 733 thanks for all recomendations in the past
Get a Mugen box I own 2 of them..............best starter box I've owned.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 06-10-2011, 01:49 PM   #3722
dawin2122's Avatar
links please thanks
dawin2122 is offline   Reply With Quote
Old 06-10-2011, 04:21 PM   #3723
NikoRacing's Avatar
I use now the Hudy's Starter Box and I'm really happy with (I'm a 1/10 driver)
My mechanic that drives a 1/8 car is also using it and he says he had no problems to run in also the most "hard engines"...
Maybe it's not the cheapest starter box but you will be very safe with it
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 06-10-2011, 05:37 PM   #3724
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i also own a HUdy, very strong motor, will turn over new 21's easy !
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-10-2011, 07:53 PM   #3725
lil-bump's Avatar
Trader Rating: 83 (100%+)
I run a Ofna and a AE starter box both have served me well. But I want a Mugen!!!!!!!
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-10-2011, 08:23 PM   #3726
links please thanks
http://www.amainhobbies.com/product_...ad-Starter-Box
Primary Weapon: ?
Secondary Weapon: ?
Old 06-11-2011, 06:26 PM   #3727
dawin2122's Avatar
ok guys i am going to sell my serpent 733 this is the pictures
Serpent 733 1/10 200mm touring-img_1232.jpg   Serpent 733 1/10 200mm touring-img_1233.jpg
Old 06-13-2011, 08:19 PM   #3728
i can't remember if i read a few pages back, but does the evo come with all the connectors etc for the new rear end design. i thought i read that it was not included in the kits but can't find the post now. if it is not included, what are the part numbers please?
implusepro is offline   Reply With Quote
Old 06-14-2011, 02:50 AM   #3729
EEL Monster's Avatar
It should come with everything except the DLS camber plate
Prt # 804224
Serpent 733TE / Reds M3T
LRP S8BX Team / Go MP5 7pt
Tamiya F104 Pro
EEL Monster is offline   Reply With Quote
Old 06-14-2011, 05:28 AM   #3730
Team Chump's Avatar
No, the Evo doesn't include the rear end connectors. Part number is #804228.
EEL Monster is also correct, you will need the DLS camber plate.
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Old 06-16-2011, 11:32 AM   #3731
Can anyone give me a advantage/disadvantage view on the front one way bearing?
Thanks.
AlvaSpeed is offline   Reply With Quote
Old 06-16-2011, 11:39 AM   #3732
and about the Axle solid front steel /alu (#804185)
Old 06-16-2011, 01:16 PM   #3733
SMcpot's Avatar
Trader Rating: 22 (100%+)
The locked front axle will work best on tracks where 4-wheel braking and a lot of on-power steering are desired. Only downside, IMO, is that the solid axle tends to be a bit harder on parts because there's no "give" in the driveline when you hit something. A front differential would be a less extreme and adjustable (although heavier) way of accomplishing the same thing.
Front oneways are best for large, fast, flowing tracks i.e., tracks without a lot of sharp, slow turns.
SMcpot is offline   Reply With Quote
Old 06-17-2011, 12:28 AM   #3734
and23's Avatar
Default News
http://www.redrc.net/2011/06/sprint-...sis-stiffener/
Andrea
Serpent 733
Max RR3
and23 is offline   Reply With Quote
Old 06-24-2011, 04:36 AM   #3735
Gergely's Avatar
Paolo, please upload the setup you used at Arcadia. Thanks!
Gergely is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
