Serpent 733 1/10 200mm touring
#3376
My 733 EVO arrived today!
Do you guys have a good setup with DLS for a European style track? I’m guessing a setup with DLS is quite different from the standard setup, what should I change?
Or should I start without DLS and first learn the car before putting it on?
My track: http://www.machheemstede.nl/ec2011/i...&id=2&Itemid=5
#3377
hello
I'd start with the box setup on the front. As far as starting without the DLS would just be your personal choice. The car feels a little different when you switch to DLS from the standard rear end but only the first lap or two. Try the box setup if you try without DLS. With DLS try 3 camber, 2.5 toe, roll center middle, and 5mm shims on the uprights.
#3378
I think it's a scandal and should be investigated
#3385
I'm running Sirio engines and I have to squeeze the fuel line between the cooling head and the INS box
#3386
I finally managed to get it in nicely, I just had to keep playing with the carb positioning and fuel inlet positioning, and shaved about 2mm off a small section of the side brace - what a pain!
#3387
hi guys, just need a bit of help on setting the camber on my 733, what sort of tyre ware patterns am i looking for on the front and the rear. also i seen a post a few pages back about putting the dls linkages to 47.7mm. what are the differences between the stock 45.5 and the 47.7? thanks in advance
#3388
#3389
I just finished building my EVO and really like it. The build went very smooth. I had only one problem, they put a small suspension bracket in the kit instead of the wide one, but that’s being fixed.
I only think it’s a bit strange that the connection parts to connect the new bulkheads and the 2speed mounts aren’t included in the kit, did they forget mine or do you have to buy them separate. I also am missing the carbon brace for the DLS. Or can you mount the aluminum parts also on the original carbon brace? (which hole?).
I’m thinking of machining the connection parts myself, which material would be most suited for the rubber one?
Thanks for the advise on setup. I think I will start without DLS and put it on when I know the car a bit better.
#3390
The DLS should have came complete. I would get the correct part from Serpent. No need to throw another variable into the mix.
Pass you soon...
