Serpent 733 1/10 200mm touring
#2506
try the optional wide foam bumper pn 804190 havent broke one since i started using it
#2507
Hi Guys i have on3 problem with my 733 , i have the new FUEL tank on my car but i have a little leaking from the cap , can someone tell me if i need to change the origial o-ring for the orange one so i can stop leaking fuel from there ??? or i need to replace the AFL CAP ?
Cheers
Cheers
#2508
Cheers
Cheers
#2509
Cheers
Cheers
#2510
733 parts cheap (below 50% cost price )
804117 PIVOT PIN FR LW X 1
804116 PIV PIN RR LW X 1
804118 PIV PIN FR UP X 1
SER73311 CVD DRIVSHAFT CSO X 1
902412 ADAPTOR 2 SPEED X 1
802261 TRACK ROD 47MM TITAN X 1
804176 GEAR DIFF SEAL RING X 1
801219 BALL 8.5 ALLUM SHORT X 1
902413 CLUTCH BELL ALUM, LC X 1
804203 REAR BELT X 4
804104 BELT FRONT X 1
804105 SIDE BELT X 3
804162 RADIO SUPPORT X 1
804188 GEAR DIFF DRIVE SHAFT LIGHT PRO X 1
803176 PIN X 1
110207 PIN X 1
804200 DIFF CASE O RING X 1
909516 CENTAX CLUTCH SPACER X 1
803226 60 T GEAR 1ST X 5
803222 54 T GEAR 2ND X 4
1649 STEEL BALL 5.8 (19) X 1
804165 BUMPER PLATE X 1
804165 BODY PLATE X 1
902416 SHOE SET 2 SPEED X 1
804181 TROTLE SPRING X 1
FUEL TANK X 1
804112 PULLEY 2SP SHAFT X 4
804148 DIFF PULLEY REAR X 3
804147 DIFF PULLEY FRONT X 4
PULLEY MIDDLE X 2
804153 ECCENTERS FRONT X 1
804152 ECCENTERS REAR X 1
804156 BRAKE LEVER /BATTERY SUPPORT X 1
804160 BEARING BRACKET X 4
804208 WISHBONE FRONT UP X 4
804161 SUSPENSION BRACKET X 3
803211 STEERING BLOCK X 3
WISH BONE REAR LW X 1
804207 WISHBONE FRONT LOWER X 2
903347 BALL JOINT DUMPER X 1
110200 PIN X 1
802211 BODY POST FRONT X 1
804155 SERVO LEVER X1
804154 SERVO LEVER FRONT X 1
903330 BRAKE PLATE X 1
804163 CHASSIS STIFFENER X 1
804190 WIDE FOAM BUMPER X 1
90241 1ST GEAR HOLDER X 1
804180 BRAKE LINKS X 1
808214 CASTER SPACER X 2
802332 DRIVE SHAFT REAR X 1
903231 BALL JOINT FRAME X 1
802361 BODY POST REAR X 1
SWAY BARS few
3 X COMPLETE DIFF SET WITH PULLEY ON THEM
1 COMPLETE CLUTCH SYSTEM WITH FLY WHEEL
SOME USED PINIONS
1 COMPLETE SET OF DRIVE SHAFT AND UNI USED ONCE .
SOME OUT OF THE PACKET stuff
1 SPARE ENGINE MOUNT . THERE IS FEW OTHER BITS AND PIECES .
$AUS 250 the lot PLUS POSTAGE No offers (National OR international buyer pm for postage cost)
803176 PIN X 1
110207 PIN X 1
FUEL TANK X 1
PULLEY MIDDLE X 2
110200 PIN X 1
SWAY BARS few
SOME USED PINIONS
#2511
What the hell!!!! last time i was on the thread we were waiting on the 710. i bought it and had one race and had my 2nd child move to another city and 6 to 7 years later.....733.
I'm living in Houston and no onroad racing going on, but still got to have one.
I selling an almost new 710 one race LOL
No i'm finding that serpent and x-ray not together. say it aint so
Whats next the Beatles breaking up.
#2512
Anyone have a problem where the side belt touches underneath the manifold?
i'm using a novarossi 2652 pipe with a 41616 header
#2513
#2514
Move the side belt tensioner under the upper deck! This will eliminate that problem and still have plenty of adjustability for tension on the belt!
#2515
#2516
#2517
thanks
Thanks rock racing.
When do they race? I looking on the internet for 733.
What set up are u running? tires, oil & etc. Has Mike strat carring parts for serpent (733).
#2519
If it slightly touches the exhaust header i wouldn't worry about it. Even before i mounted my belt tensioner under the upper deck i never had a problem with side belts wearing out or having it effect the freedom of my drivetrain.
#2520
Well, it worked for me. It's real close but it's not touching.
