Serpent 733 1/10 200mm touring
#2446
Ah, ok. Thanks for you help
Will this one do for example?
http://www.globy.no/page/products/142224/
Do I have to take the "gearbox" apart to put the grease on? Where exactly do I put the grease? (I sound like a newbie because I am one )
when you apply the grease, http://www.serpent.com/product/902411/ put a little inside on the needle rollers. turn it a few times, and wipe off any excess from this part http://www.serpent.com/product/902412/
#2447
This is what I use, just add about a toothpick amount and work it in.
http://www.atomicmods.com/Products/T...cc__14767.aspx
Or....if anyone is lucky enough to have the old school serpent one way lube (purple bottle) then you could put a few drops a race and be solid. I found a bottle that i had from 12 years back and its the best ever made. If you put a drop on your fingers and rub it in it feels dry but lubed. someone needs to make this stuff again.
#2448
#2452
Thanks a lot for all your help guys, I really appreciate it! You might just have saved me a burned out OWB, and a fair amount of unnessecary fiddling
One last question; do I have to disassemble the gearbox everytime I want to lube the OWB? Or can it be done without disassembling it?
#2453
#2454
I have a problem with the nut to tighten the flywheel of my centax clutch on my 353.
I can't get it off anymore, turning in both directions has no effect anymore. Any tips/suggestions how to get it off? I am a little bit affraid to just start using the dremel on my engine.
#2455
#2456
it isn't, unfortunately. I know for sure that the nut is slightly dull. It turns heavy in both ways, but doesn't come off or tightens.
#2457
if it is the cone, try filing the front f it, so the nut isnt tightening on the cone , but on the flywheel. i suspect the cone is protruding through the flywheel and the nut is hard up on the cone.
#2458
I'll take a look at that, but I am pretty sure its the nut itself who is damaged. When I put a full turn on the nut in either direction I don't feel the compression of the piston getting to its TDC. when i turn the flywheel a full turn i notice the compression very clear.
#2459
#2460
Patto, you were right, the crank is turning with the nut! whis means the flywheel is loose, not the nut. Blocking the piston usin a tierap did the job. Thanks guys, i messed this one up
