Shepherd Velox V10
#1081
#1082
Suspended
#1084
The v10 was a treat to run short of the battery pack which we will be working on to resolve. It was our first major outing with it and it performed superbly.
Transmission was faultless, the out of box setup was drivable and the most impressive aspect was the balance of the car. When the tail snapped out it had a tendency to correct itself. Most impressed.
Check out Jeff Hamon's suspension setup thru the sweep compared to Mugens and Capricorns.
http://www.youtube.com/user/therealb.../0/7Cay8TnBUwc
cheers
h
cheers
h
After the event we brought it home for a full rebuild and found the front CV pins had pulled themselves out of the wheel hub/axle and we had to cut the hub apart to rectify. My son replaced the pin and I removed the circuitry from the Lithium battery pack. While on track a racing buddy rectified the loose bearing in the transmission by using a pin punch.
Apart from those minor issues, it's an awesome car.
PS: Oh yeah I forgot, the tiny clutch bell bearing was flogged out, not surprising though.
#1085
Hello,
I got these arm's from a fellow racer at the track this weekend. Does anyone know when these will be released? Or if they are what is the part #? I assume they are being made because they are not the white plastic that is used for testing. I first saw pictures of the arms on Mark's car from the worlds. Any help would be great!
Thanks!
Thanks!
#1086
Is this GMac?
Hello,
Thanks!
Thanks!
#1087
team shepherd?? , saludos Dru.. take care of yourself..
Yukiyu
Yukiyu
#1089
just picked up a used v10
just picked up a used velox v 10 car is stock need some advise on up grade parts and where to get them. thanks in advance
#1090
We just received the Capricorn Clutch for the V10.
Call your LHS to order or contact us @ 3056773253
#1094
up grade parts
who has up grade parts for v10 and what parts to up grade ? thanks
