Shepherd Velox V10
#571
http://rcmarket.com.hk/product_info....oducts_id=6231
#572
thanks for that, bit pricey though, the dimensions of that pack are they about as big as you can go?
found one 20mm longer at $15 guessing that wont fit
#574
Suspended
#575
progress
Hey Novarossi,
what has happened to the regular updates on the build or have you finished the build ??????????????
Cheers Michael
Cheers Michael
#576
I only found 1 life pack that can fit the v10 but its only 1100mah if that matters.
http://www.rc-toro.com/product_info....oducts_id/1666
#577
#580
#581
yes, new pictures please
#583
Here we go, sorry for the long delay...
The shocks are by far the best I have ever built. I think it is the car's best feature. Absolutely zero air, perfect rebound - BRILLANT SHEPHERD!
Also, a photo of the brake pads. I did not need to sand them down, they went on without binding.
#585
Hello,
I have some questions regarding the V10 clutch. Does anyone have some issues? I have two clutches and on both the same problem … the three pins on the flywheel don’t fit the steel disc and clutch shoe properly! The fit is very tight and it doesn’t moves freely. So I bent the pins a little bit to get smooth movement. Now it seems OK.
Regards!
Regards!
