Old 02-23-2009, 01:41 PM   #1
Gerner's Avatar
Default Carbon chassis?
Hey,
What would happen if I made a carbon chassis for my 1:10 nitro, would it kill the engine or ruin balance due to weight loss?
Has anyone tried that and failed or succeeded?
God does not exist
Putin for world prez
Gerner is offline   Reply With Quote
Old 02-23-2009, 01:54 PM   #2
wizby's Avatar
I believe heat is disipated through the aluminum chassis.
I know my chassis is quite hot after a long run. Might need to find another way to bleed off that heat.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 02-23-2009, 02:08 PM   #3
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Originally Posted by Gerner View Post
Hey,
I have worked with this for about 3 1/2 years with a touring car and also another 3 -4 years with pan cars. Look at this link to answer some questions........ I have done this for the MTX3 MTX4 and the NT1 with success and without having a temp issue....actualy lowered the temps because of the disipitation of the carbon fiber. Even when cutting the carbon fiber dry with high speed tooling, it remains cool to the touch.
http://www.rctech.net/forum/5469422-post3814.html
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 02-23-2009, 02:32 PM   #4
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I actually still have the MTX4 carbon chassis that James (rcfoolz) sent to me for testing. I was almost positive that I would engine temp issues but I didn't. Now, I will say that without changing anything else my car did traction roll a bit easier than with the aluminun chassis.
My guess is that if I had done some other setup changes I might have been able to make the car good. Also, I was running on a high bite VHT track at the time. With a low bit track, the carbon fiber chassis might have actually been better.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-23-2009, 02:39 PM   #5
Gerner's Avatar
Thanks, but what is the link?
God does not exist
Old 02-23-2009, 02:43 PM   #6
Nitro-Racer*'s Avatar
there is some fresh information about carbon chassis in the xray forum
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 02-23-2009, 02:56 PM   #7
Francis M.'s Avatar
I would stick with aluminum.... The car is gonna be top heavy not unless you add weight back to the chasis which defeats the purpose of CF chasis...
CF also tends to delaminate when it is dragged enough and It will eventually splinter....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-23-2009, 03:13 PM   #8
rcfoolz's Avatar
100% correct, it will delaminate.
When I built the first one 3 1/5 years ago, I had a source on Associated Chassis Protector, a .5mm thick sheet of teflon that covered the chassis from front to rear. The car that I had built it for had more mods done to it so that the wieght of the car was lowered. Some may remember some of what I had done. I had lowered the radio deck 2mm along with the fuel tank an additional 2mm (4mm total) and the bulkeads had been modded for 1.5mm lower stance at the bottom along with everthing that attached to the top was lowered an additional 1mm, making the car thinner than the current NT1. With the aluminum chassis, I used this car to win the "C" main in the 2006 Winternats and did not take a bump to the "B"...I was the only non sponsored driver in the top 30 that year in sedan. The Roll-center bridge, shock towers and radio deck had all been made specific to that car to lower the CG and wieght. The car was a lot of work and to undertake the amount of time to modify it was 2 months. It however did handle very well and one thing that I remember was that I had almost no tire wear and everybody was having tire wear issues that year.
Sorry for the long story, but if anybody is considering converting to one, rember that your current setup won't work and you will have to change your setup mechanicly to lower CG and roll center. I'm just suprized to see that a mainline mfg is making them now.
Old 02-24-2009, 01:59 AM   #9
Gerner's Avatar
Dude, thanks
I think i will try it out just for the fun since I spend a lot of energy to make the car as light as possible.
I know shocks should be configured for lower weight, but how about the diffs, stock mine are with very thick oil, how thin should it be if just for an examble the car weighs in at 1500 grams?
God does not exist
Old 02-24-2009, 04:11 AM   #10
rcfoolz's Avatar
Dude, thanks
What you are going to find is that thicker diff fluid or even a spool in the front is going to help more than thinner oil.
Old 02-24-2009, 03:01 PM   #11
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that mtx3 looks awfully familiar
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-24-2009, 07:07 PM   #12
rcfoolz's Avatar
Hmmm....yep
Old 02-26-2009, 01:25 PM   #13
getpip's Avatar
James ... are you still making these? ... they sound like a bit of fun.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 02-26-2009, 02:01 PM   #14
RC MARKET's Avatar
HK was release carbon graphite for NT-1 ,
it's from HK Top driver release ,
his point is lower CG & LW, cool down is from air in your body window hole .
but life is shorter than Alum. , fit for not have more bump driver in race .
http://rcmarket.com.hk/product_info....m07p33fh6gc9o6
RC MARKET is offline   Reply With Quote
Old 02-26-2009, 02:23 PM   #15
I can send you "my" MTX4 chassis if James doesn't have any. I still have mine.
Team Associated TC5 RCknight Electric On-Road 13256 Yesterday 05:13 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
Carbon Fiber TC3 chassis, Xtreme Racing OOde R/C Items: For Sale/Trade 9 07-06-2007 08:33 PM
Servos; Charger; Motor; Chassis Darkshinobi R/C Items: For Sale/Trade 33 01-12-2007 04:18 PM
EOI MTX4 loaded with options for sale TomB Australia For Sale/Trade 14 12-21-2006 08:54 PM
Electric Buggy Choices? RoostAZ Electric Off-Road 25 06-19-2006 05:06 PM
