Serpent 710
Originally posted by InitialD
Julius, I am currently using more vertical shocks on the 710 in the rear and as well as in the front. I found them to make the car very neutral and easy to drive.
Are you sure your rear sway bar mounting on the lower rear arm is in the inner part and not on the outer (stock)? Just thought to remind you if you overlooked this part. Inner mounting on the rear bottom arms with the ball cups mounted at the end of the bar is the softest setting.
What shock oil weight is that? You could also try slightly more rear toe in to tame the rear.
I got 35 w shock oil with the innerfoams allround 4 holes open.
Found also that my initial setting of my reardiff was way to tight so it works better now. Hope I have some time this week but the weather is awfull and next weekend the bigguns (1/8th) have a nationalrace at our track so have to watch instead of race
I think I put the shocks back as Julius suggested and start from there.
Thanks for the help guys
Super Moderator
Re: Re: old impulse
Marcos, that's an oldie goldie alright !
Originally posted by Julius
What do you feel is different compared to stiffer springs and damping?
Super Moderator
Re: Re: old impulse
Check out my 710 C-spec.
Re: Re: Re: old impulse
Originally posted by Marcos.S710
hey "D" here is another of my oldies
Wait till Serpent comes out with the F1.
Super Moderator
Re: Re: Re: Re: old impulse
Those are cool Marcos but it's a Kyosho.
802241
Just realised that Serpent came out with the front aluminum sway bar holders. Orange !
Re: 802241
Re: Re: 802241
Originally posted by FW05R
OMG THAT LOOKS SIKK I WANT ONE DO YOU TAKE PAYPAL D
I hope you knew those parts are from Serpent !
http://www.mytsn.com/products/desc.asp?prid=3356
Re: Re: Re: 802241
Give me your CC number ! (j/k)
re anti roll bar alu.
I wish they come out more aluminium part in orange so the color scheme on the car will be more consistent
Re: re anti roll bar alu.
